2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: pvaGateway Access Control questions
From: "Murray, Doug via Core-talk" <core-talk at aps.anl.gov>
To: "Michael A. Davidsaver" <mdavidsaver at ospreydcs.com>
Cc: EPICS CoreTalk <core-talk at aps.anl.gov>
Date: Wed, 12 Jul 2023 15:59:44 +0000
Hi Michael, here at SLAC we’re planning to run both CA and PVA gateways concurrently on the same subnet using the same access control files.  However, the documentation says the existing CA files (ACF/pvlist) are not fully compatible with the pvaGateway.
The specific concern is that several CA gateways are currently configured with the DENY,ALLOW evaluation order to support multiple gateway instances on the same subnet.
I believe that the original CA gateway instance became overloaded, so a second one was deployed to balance the load. Gateway 1 only provided access to half the PVs by denying access to some and granting access to others.  Then gateway 2 was configured in the opposite way, granting access to those PVs denied by gateway 1 but denying access to the others.
The pvaGateway documentation clearly indicates that the DENY,ALLOW evaluation order is not supported, so I was going to suggest we use a single pvaGateway instance with its own ACF/pvlist.   Do you have any suggestions or advice?
cheers
-doug
Re: pvaGateway Access Control questions Michael Davidsaver via Core-talk
Prev: Build completed: EPICS Base 7 base-7.0-965 AppVeyor via Core-talk
Next: Re: pvaGateway Access Control questions Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
ANJ, 12 Jul 2023 · Home · News · About · Talk · Base · Modules · Extensions ·
