2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: [Bug 2029482] Re: pvget json error
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Mon, 07 Aug 2023 04:59:53 -0000
This fix has been merged into the pvDataCPP module and will appear in
the next EPICS 7.0.x release, thanks for the report.
** Changed in: epics-base/7.0
       Status: Triaged => Fix Committed
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/2029482
Title:
  pvget json error
Status in EPICS Base:
  Fix Committed
Status in EPICS Base 7.0 series:
  Fix Committed
Bug description:
  I’ve been using `pvget -M json` and have noticed a problem with it
  when the PV has the alarm fields set like so:
  double lowAlarmLimit nan
  double lowWarningLimit nan
  double highWarningLimit nan
  double highAlarmLimit nan
  When I run pvget I get the following:
  > pvget -M json IOC:m1.RBV
  IOC:m1.RBV {"value":88.129999999999995,"alarm":{"severity":0,"status":0,"message":"NO_ALARM"},"timeStamp":{"secondsPastEpoch":1691063460,"nanoseconds":182366000,"userTag":0},"display":{"limitLow":-100.0,"limitHigh":100.0,"description":"motor 1","units":"degrees","precision":5,"form":{"index":0,"choices":["Default","String","Binary","Decimal","Hex","Exponential","Engineering"]}},"control":{"limitLow":-100.0,"limitHigh":100.0,"minStep":0.0},"valueAlarm":{"active":false,"lowAlarmLimit"Error in monitor handler : yajl_gen_invalid_number
  It looks like YAJL doesn’t like the nan values. If I set them to non-
  nan values then the error goes away.
  This is with base 7.0.7.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/2029482/+subscriptions
[Bug 2029482] [NEW] pvget json error Matt Clarke via Core-talk
Prev: [Bug 2029482] Re: pvget json error Matt Clarke via Core-talk
Next: [Bug 2029482] Re: pvget json error Matt Clarke via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
ANJ, 07 Aug 2023 · Home · News · About · Talk · Base · Modules · Extensions ·
