Public bug reported:
I’ve been using `pvget -M json` and have noticed a problem with it when
the PV has the alarm fields set like so:
double lowAlarmLimit nan
double lowWarningLimit nan
double highWarningLimit nan
double highAlarmLimit nan
When I run pvget I get the following:
> pvget -M json IOC:m1.RBV
IOC:m1.RBV {"value":88.129999999999995,"alarm":{"severity":0,"status":0,"message":"NO_ALARM"},"timeStamp":{"secondsPastEpoch":1691063460,"nanoseconds":182366000,"userTag":0},"display":{"limitLow":-100.0,"limitHigh":100.0,"description":"motor 1","units":"degrees","precision":5,"form":{"index":0,"choices":["Default","String","Binary","Decimal","Hex","Exponential","Engineering"]}},"control":{"limitLow":-100.0,"limitHigh":100.0,"minStep":0.0},"valueAlarm":{"active":false,"lowAlarmLimit"Error in monitor handler : yajl_gen_invalid_number
It looks like YAJL doesn’t like the nan values. If I set them to non-nan
values then the error goes away.
This is with base 7.0.7.
** Affects: epics-base
Importance: Undecided
Status: New
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/2029482
Title:
pvget json error
Status in EPICS Base:
New
Bug description:
when the PV has the alarm fields set like so:
nan values then the error goes away.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/2029482/+subscriptions
- [Bug 2029482] Re: pvget json error Andrew Johnson via Core-talk
- [Bug 2029482] Re: pvget json error Matt Clarke via Core-talk
Re: What is the next step for RTEMS and EPICS? Does a small (virtual) workshop make sense? Chris Johns via Core-talk
Re: What is the next step for RTEMS and EPICS? Does a small (virtual) workshop make sense? Andrew Johnson via Core-talk
<2023>
2025
2026
Build failed: EPICS Base 7 base-7.0-981 AppVeyor via Core-talk
<2023>
2025
2026
