The version of yajl that comes with Base 7.0.6.1 and later can generate
JSON5 which handles infinities and NaN values, but it looks like the
pvAccess code in pvget isn't enabling that option in the print
formatter. Applying the following patch to modules/pvData should fix it:
diff --git a/src/factory/printer.cpp b/src/factory/printer.cpp
index 928fc4f..31f7116 100644
--- a/src/factory/printer.cpp
+++ b/src/factory/printer.cpp
@@ -404,6 +404,9 @@ std::ostream& operator<<(std::ostream& strm, const PVStructure::Formatter& forma
if(format.xfmt==PVStructure::Formatter::JSON) {
JSONPrintOptions opts;
opts.multiLine = false;
+#if EPICS_VERSION_INT>=VERSION_INT(7,0,6,1)
+ opts.json5 = true;
+#endif
printJSON(strm, format.xtop, format.xshow ? *format.xshow : BitSet().set(0), opts);
strm<<'\n';
return strm;
Given that this is actually a bug against pvDataCPP I have filed an
issue against that module on GitHub referring to this bug report:
https://github.com/epics-base/pvDataCPP/issues/92
** Bug watch added: github.com/epics-base/pvDataCPP/issues #92
** Changed in: epics-base
Status: New => Triaged
Importance: Undecided => Medium
** Also affects: epics-base/7.0
Importance: Medium
Status: Triaged
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/2029482
Title:
pvget json error
Status in EPICS Base:
Triaged
Status in EPICS Base 7.0 series:
Triaged
Bug description:
I’ve been using `pvget -M json` and have noticed a problem with it
when the PV has the alarm fields set like so:
double lowAlarmLimit nan
double lowWarningLimit nan
double highWarningLimit nan
double highAlarmLimit nan
When I run pvget I get the following:
> pvget -M json IOC:m1.RBV
IOC:m1.RBV {"value":88.129999999999995,"alarm":{"severity":0,"status":0,"message":"NO_ALARM"},"timeStamp":{"secondsPastEpoch":1691063460,"nanoseconds":182366000,"userTag":0},"display":{"limitLow":-100.0,"limitHigh":100.0,"description":"motor 1","units":"degrees","precision":5,"form":{"index":0,"choices":["Default","String","Binary","Decimal","Hex","Exponential","Engineering"]}},"control":{"limitLow":-100.0,"limitHigh":100.0,"minStep":0.0},"valueAlarm":{"active":false,"lowAlarmLimit"Error in monitor handler : yajl_gen_invalid_number
It looks like YAJL doesn’t like the nan values. If I set them to non-
nan values then the error goes away.
This is with base 7.0.7.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/2029482/+subscriptions
- [Bug 2029482] [NEW] pvget json error Matt Clarke via Core-talk
Build failed: EPICS Base 7 base-7.0-983 AppVeyor via Core-talk
Re: What is the next step for RTEMS and EPICS? Does a small (virtual) workshop make sense? Chris Johns via Core-talk
<2023>
2025
2026
[Bug 2029482] Re: pvget json error Matt Clarke via Core-talk
<2023>
2025
2026
