2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: PVA Gateway (p4p) is Missing some Status PVs
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: "Murray, Doug" <drm at slac.stanford.edu>
Cc: EPICS CoreTalk <core-talk at aps.anl.gov>
Date: Thu, 24 Aug 2023 11:43:49 +0200
On 8/23/23 09:56, Murray, Doug wrote:
We’ve been setting up the latest version of the p4p PVA Gateway (R4.1.9) and have noticed that a couple status PVs are no longer providing expected results.
  * The *<statusprefix>cache* PV always returns an empty list, but previously provided “a list of channels to which the GW Client is connected”.
This was an oversight when porting to PVXS.  I had a couple of TODO items
which did not get marked as such.
https://github.com/mdavidsaver/p4p/commit/2930d9fcc0370ef3f292f5d24a46d1b4ef98f314#diff-8061cbf72533fa48d08f5f9891a94f5ebeaaffbba7f9e5cdae7aa10d594d09deR945
  * The *<statusprefix>ds:byhost:tx* PV always provides the same client host address as 255.255.255.255, regardless of the client’s true IP address.
Can you provide some more detail?
My usual testing is all on one host with different ports.  So I can see
how I might not notice an issue like this.  However, I can check the port
numbers with the output of `netstat -tpn`.  From what I see, I think the
IP:port reported by in the ds: and us: tables are socket peer addresses.
These were working well in previous versions.  Has anybody else encountered this?
cheers
-doug
SLAC
Re: PVA Gateway (p4p) is Missing some Status PVs Heinz Junkes via Core-talk
PVA Gateway (p4p) is Missing some Status PVs Murray, Doug via Core-talk
Prev: PVA Gateway (p4p) is Missing some Status PVs Murray, Doug via Core-talk
Next: Re: PVA Gateway (p4p) is Missing some Status PVs Heinz Junkes via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
ANJ, 24 Aug 2023 · Home · News · About · Talk · Base · Modules · Extensions ·
