2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: Gateway crashes
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: Ralph Lange <ralph.lange at gmx.de>
Cc: EPICS Core Talk <core-talk at aps.anl.gov>
Date: Fri, 22 Sep 2023 08:34:38 -0700
On 9/22/23 06:51, Ralph Lange via Core-talk wrote:
On Fri, 22 Sept 2023 at 15:33, Zimoch Dirk <dirk.zimoch at psi.ch <mailto:dirk.zimoch at psi.ch>> wrote:
    Do you have a coredump?
I asked for one.
It's a production system, with no access for me. Also, with Gateways running as system daemons, I'm not sure that coredumps are allowed by default.
You might check if systemd coredump collection is enabled.  (cf 'man coredumpctl')
If there is a "simple" deadlock, then valgrind w/ --tool=helgrind or drd may pick
it up.  Of course, this would not catch eg. a missing epicsMutexUnlock() on an
error path.
Gateway crashes Ralph Lange via Core-talk
Re: Gateway crashes Zimoch Dirk via Core-talk
Re: Gateway crashes Ralph Lange via Core-talk
Prev: Re: Gateway crashes Zimoch Dirk via Core-talk
Next: Build failed: EPICS Base 3.15 base-3.15-101 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: Gateway crashes Ralph Lange via Core-talk
Next: Re: Gateway crashes Zimoch Dirk via Core-talk
ANJ, 22 Sep 2023 · Home · News · About · Talk · Base · Modules · Extensions ·
