2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: Gateway crashes
From: Zimoch Dirk via Core-talk <core-talk at aps.anl.gov>
To: "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>, "ralph.lange at gmx.de" <ralph.lange at gmx.de>
Date: Fri, 22 Sep 2023 14:13:37 +0000
The assert basically complains that we have a deadlock (and the mutex has error
check enabled or is recursive, which all epicsMutexes are). That means we are
trying to lock a mutex that is already locked by someone else. Without a core
dump it seems impossible to find out which EPICS mutex it may be.
The glibc code in question seems to be here (now at line 420):
https://github.com/lattera/glibc/blob/895ef79e04a953cac1493863bcae29ad85657ee1/nptl/pthread_mutex_lock.c#L420C33-L420C33
On Fri, 2023-09-22 at 15:33 +0200, Zimoch Dirk wrote:
> Do you have a coredump?
> On Fri, 2023-09-22 at 14:03 +0200, Ralph Lange via Core-talk wrote:
> > We are seeing CA Gateway crashes that log
> > gateway: ../nptl/pthread_mutex_lock.c:430: __pthread_mutex_lock_full: Assertion `INTERNAL_SYSCALL_ERRNO (e, __err) != EDEADLK || (kind != PTHREAD_MUTEX_ERRORCHECK_NP && kind != PTHREAD_MUTEX_RECURSIVE_NP)' failed.
> > which is from glibc code. I have never seen that before.
> > Looks like a Gateway thread died without releasing a semaphore?
> > Scared,
> > ~Ralph
Re: Gateway crashes Zimoch Dirk via Core-talk
Gateway crashes Ralph Lange via Core-talk
Prev: Re: Gateway crashes Ralph Lange via Core-talk
Next: Re: Gateway crashes Zimoch Dirk via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: Gateway crashes Michael Davidsaver via Core-talk
ANJ, 22 Sep 2023 · Home · News · About · Talk · Base · Modules · Extensions ·
