See <https://jenkins.aps.anl.gov/job/epics-pva2pva-win64/516/display/redirect?page=changes>
Changes:
[Michael Davidsaver] Allow "meta" at member top of array of struct
[Michael Davidsaver] add DTYP="QSRV Demo Replicate"
[Michael Davidsaver] oops
Started by an SCM change
Running as SYSTEM
[EnvInject] - Loading node environment variables.
Building in workspace <https://jenkins.aps.anl.gov/job/epics-pva2pva-win64/ws/>
The recommended git tool is: NONE
No credentials specified
Cloning the remote Git repository
Cloning repository https://github.com/epics-base/pva2pva.git
> git init <https://jenkins.aps.anl.gov/job/epics-pva2pva-win64/ws/> # timeout=10
Fetching upstream changes from https://github.com/epics-base/pva2pva.git
> git --version # timeout=10
> git --version # 'git version 1.8.3.1'
Setting http proxy: webgateway221.anl.gov:9091
> git fetch --tags --progress https://github.com/epics-base/pva2pva.git +refs/heads/*:refs/remotes/origin/* # timeout=10
> git config remote.origin.url https://github.com/epics-base/pva2pva.git # timeout=10
> git config --add remote.origin.fetch +refs/heads/*:refs/remotes/origin/* # timeout=10
Avoid second fetch
> git rev-parse refs/remotes/origin/master^{commit} # timeout=10
Checking out Revision 4cb3d4d696a761c619adfe34b53ecbe6dcb000c3 (refs/remotes/origin/master)
> git config core.sparsecheckout # timeout=10
> git checkout -f 4cb3d4d696a761c619adfe34b53ecbe6dcb000c3 # timeout=10
Commit message: "oops"
> git rev-list --no-walk 3b9990e3650fca2673eebfb83645193ac0e5297d # timeout=10
[workspace] $ cmd /c call /tmp/jenkins1672370424242724755.bat
FATAL: command execution failed
java.io.IOException: error=2, No such file or directory
at java.base/java.lang.ProcessImpl.forkAndExec(Native Method)
at java.base/java.lang.ProcessImpl.<init>(ProcessImpl.java:340)
at java.base/java.lang.ProcessImpl.start(ProcessImpl.java:271)
at java.base/java.lang.ProcessBuilder.start(ProcessBuilder.java:1107)
Caused: java.io.IOException: Cannot run program "cmd" (in directory "<https://jenkins.aps.anl.gov/job/epics-pva2pva-win64/ws/")>: error=2, No such file or directory
at java.base/java.lang.ProcessBuilder.start(ProcessBuilder.java:1128)
at java.base/java.lang.ProcessBuilder.start(ProcessBuilder.java:1071)
at hudson.Proc$LocalProc.<init>(Proc.java:252)
at hudson.Proc$LocalProc.<init>(Proc.java:221)
at hudson.Launcher$LocalLauncher.launch(Launcher.java:994)
at hudson.Launcher$ProcStarter.start(Launcher.java:506)
at hudson.tasks.CommandInterpreter.perform(CommandInterpreter.java:144)
at hudson.tasks.CommandInterpreter.perform(CommandInterpreter.java:92)
at hudson.tasks.BuildStepMonitor$1.perform(BuildStepMonitor.java:20)
at hudson.model.AbstractBuild$AbstractBuildExecution.perform(AbstractBuild.java:818)
at hudson.model.Build$BuildExecution.build(Build.java:199)
at hudson.model.Build$BuildExecution.doRun(Build.java:164)
at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:526)
at hudson.model.Run.execute(Run.java:1895)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:44)
at hudson.model.ResourceController.execute(ResourceController.java:101)
at hudson.model.Executor.run(Executor.java:442)
Build step 'Execute Windows batch command' marked build as failure
[MSBuild] Skipping execution of recorder since overall result is 'FAILURE'
Build failed in Jenkins: 3.15-pva2pva-win64s #351 APS Jenkins via Core-talk
Build failed in Jenkins: epics-pvData-win64 #652 APS Jenkins via Core-talk
<2023>
2025
2026
<2023>
2025
2026
