2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: EPICS Core github CI
From: Chris Johns via Core-talk <core-talk at aps.anl.gov>
To: Core-talk <core-talk at aps.anl.gov>
Date: Tue, 14 Nov 2023 09:46:23 +1100
Hello,
At an EPICS meeting earlier this year there was a discussion about the CI
tooling for RTEMS builds. I would like to discuss and help plan moving the CI
tools for RTEMS to RTEMS 6.
The RTEMS developers recommend moving to RTEMS 6 however Michael and Andrew
rightly pointed out it is not released. What is being offered is an interim
solution until it is released with the focus on establishing a tools and kernel
supply chain that makes upgrading simpler than it currently is.
The ci-scripts README discusses support for RTEMS 5 and 10 BSPs. The move to
RTEMS 6 has extra dependencies that complicates building all the needed pieces.
The solution offered in the meeting was to use Gemini's infrastructure to build
containers with the suitable tools, BSPs and networking libraries installed. We
are working on this. The piece we need help with is the github CI integration. I
know very little about github and its CI interfaces.
Details
Gemini's gitlab workflows use the rtems-deployment repo to build RPM packages
for specific configurations. I have defined an initial set of BSPs:
 https://git.rtems.org/chrisj/rtems-deployment.git/tree/config/epics
This repo uses an RSB clone which defines the specific version of RTEMS. As a
result we can control the version of RTEMS built and we can add specific RPM
version settings to track what is installed in a container.
The RPMs are installed into containers that can be used to build EPICS base.
There are 2 RPMs built, one for the legacy networking stack and one for the
libbsd networking stack. Both RPMs contain the RTEMS net-services libraries for
things like NTP. The legacy stack supports NFSv2 and libbsd supports NFSv4.
Status
The building of the RPMs by Gemini is effected by the outage Gemini has and
Felix has been looking for ways to build without it but it is not easy and I ask
for your patience while we work through this.
Questions, issues and suggestions are welcome
Thanks
Chris
Re: EPICS Core github CI Michael Davidsaver via Core-talk
Prev: Build failed: epics-base base-bi-raw-mask-1014 AppVeyor via Core-talk
Next: Re: EPICS Core github CI Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
ANJ, 15 Nov 2023 · Home · News · About · Talk · Base · Modules · Extensions ·
