The IOC servers can't do what you're trying, any port they accept connections through will be r/w unless you configure Access Security for the clients, in which case you don't need the second port. Michael
added IP address support to the access security system fairly recently (I forget if you have to turn it on though), so if you know what all the IP addresses or DNA names are of one or the other client groups (r/w or r/o) you can just set up an access security
file with a HAG containing just those addresses. I forget whether it allows for subnet addresses. However, that only works for IOCs recent-enough versions of Base.
It would be relatively easy to run separate CA (and PVA) gateways on a other ports to provide read-only access; this would work for all EPICS versions.
- Andrew
Complexity comes for free, Simplicity you have to work for.
On 1/26/24, 10:50 AM, "Core-talk" <core-talk-bounces at aps.anl.gov> wrote:
Hi folks,
Today someone asked me if it is possible to filter write access to records with
a firewall. The idea is to run a read/write server and a read-only server on the
same IOC on two different ports.
I guess the answer is no. At least my attempts to start two CA server on the
same IP address failed. I tried:
EPICS_CAS_INTF_ADDR_LIST="<my IP> <my IP>:5070"
But it seems ports are ignored in EPICS_CAS_INTF_ADDR_LIST.
Also, I would not know how to make a server readonly. All
Would this be a "simple" way to handle write access filtering per firewall
rules, opening the r/w port only to selected client IP addresses?
Dirk
- Re: separate ca/pva ports for r/w and r/o access? Ralph Lange via Core-talk
- separate ca/pva ports for r/w and r/o access? Zimoch Dirk via Core-talk
<2024>
2025
2026
<2024>
2025
2026
ANJ, 26 Jan 2024 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
