It would be relatively easy to run separate CA (and PVA) gateways on a other ports to provide read-only access; this would work for all EPICS versions.
Yes. If these Gateways are running on the same host and connect to the IOC through localhost/loopback, the difference to Dirk's original idea would be pretty hard to tell from the outside. If the IOC handles read-write vs. read-only, the Gateway configuration is trivial.
Cheers, ~Ralph
- Re: separate ca/pva ports for r/w and r/o access? Zimoch Dirk via Core-talk
- separate ca/pva ports for r/w and r/o access? Zimoch Dirk via Core-talk
- Re: separate ca/pva ports for r/w and r/o access? Johnson, Andrew N. via Core-talk
<2024>
2025
2026
<2024>
2025
2026
ANJ, 29 Jan 2024 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
