Hi Andrew, Ralph,
Thanks for your input. I will suggest the gateway solution to my customer.
Dirk
On Fri, 2024-01-26 at 20:02 +0100, Ralph Lange via Core-talk wrote:
> On Fri, 26 Jan 2024 at 19:38, Johnson, Andrew N. via Core-talk <core-talk at aps.anl.gov> wrote:
> > It would be relatively easy to run separate CA (and PVA) gateways on a other ports to provide read-only access; this would work for all EPICS versions.
> Yes.
> If these Gateways are running on the same host and connect to the IOC through localhost/loopback, the difference to Dirk's original idea would be pretty hard to tell from the outside.
> If the IOC handles read-write vs. read-only, the Gateway configuration is trivial.
> Cheers,
> ~Ralph
- separate ca/pva ports for r/w and r/o access? Zimoch Dirk via Core-talk
- Re: separate ca/pva ports for r/w and r/o access? Johnson, Andrew N. via Core-talk
- Re: separate ca/pva ports for r/w and r/o access? Ralph Lange via Core-talk
caRepeater question Zimoch Dirk via Core-talk
<2024>
2025
2026
<2024>
2025
2026
