My 2cts. . . On Tue, 27 Feb 2024 at 23: 51, Mark Rivers via Core-talk <core-talk@ aps. anl. gov> wrote: ZjQcmQRYFpfptBannerEnd Hi Torsten, Ø The PLC gives us some names for enmums, resulting in a call to Ø pC_->doCallbacksEnum() doCallbacksEnum()
ZjQcmQRYFpfptBannerStart
This Message Is From an External Sender
This message came from outside your organization.
My 2cts...
Been there... The problem is that these are synchronous (blocking) calls. If you have many devices and/or devices that are handled asynchronously, this is likely to screw up your IOC startup.
I think the most reasonable way to handle the situation is a bit more complex: - from the driver, do the requests to the devices as early as possible after the devices are up (and do the requests in parallel),
- when the responses come in, queue them,
- start the worker thread(s) for the queues (that push the values into the database) when the IOC is fully up, through the interruptAccept initHook.
That will work no matter if the IOC becomes ready before, during or after the initial device readout is finished. Queueing incoming responses is always a good idea that helps with bursts or high-load-on-the-IOC-host situations.
Cheers, ~Ralph
- Re: pC_->doCallbacksEnum() coming too early Torsten Bögershausen via Core-talk
- pC_->doCallbacksEnum() coming too early Torsten Bögershausen via Core-talk
- Re: pC_->doCallbacksEnum() coming too early Johnson, Andrew N. via Core-talk
- RE: pC_->doCallbacksEnum() coming too early Mark Rivers via Core-talk
Build failed: EPICS Base 7 base-7.0-1107 AppVeyor via Core-talk
<2024>
2025
2026
<2024>
2025
2026
ANJ, 28 Feb 2024 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
