It seems I missed that line in my commit b1f445925d when I changed dbLinks from
DBADDR to dbChannel in order to allow the use of link filters.
Dirk
On Fri, 2024-06-14 at 17:45 -0700, Michael Davidsaver via Core-talk wrote:
> A little C code "challenge" which puzzled me today.
> Why was the following change a no-op?
> As background. For DB_LINK, the type stored in
> 'plink->value.pv_link.pvt' changed from 'DBADDR*'
> to 'dbChannel*' back with Base 3.15.0.1. I was
> quite surprised to notice that dblsr() was still
> treating it as a 'DBADDR*'.I initially assumed
> that no one had tested it since then. But, after
> thinking for awhile, I realized that the
> situation was not so simple.
> > --- a/modules/database/src/ioc/db/dbLock.c
> > +++ b/modules/database/src/ioc/db/dbLock.c
> > @@ -918,7 +918,7 @@ long dblsr(char *recordname,int level)
> > pdbFldDes = pdbRecordType->papFldDes[pdbRecordType->link_ind[link]];
> > plink = (DBLINK *)((char *)precord + pdbFldDes->offset);
> > if(plink->type != DB_LINK) continue;
> > - pdbAddr = (DBADDR *)(plink->value.pv_link.pvt);
> > + pdbAddr = &((dbChannel *)(plink->value.pv_link.pvt))->addr;
> https://urldefense.us/v3/__https://github.com/epics-base/epics-base/commit/72d50ce2749bbc791907a32c1ed77af1333a21f5__;!!G_uCfscf7eWS!bqiRBiT_Ip0nrcLGxrmm1ZE6yiy1TzCcEIkBjZ30UI_daWaDnRhBenpKVMd1dyXCfbUXcYySljDXqZ16jZH7AIP8Qg$
> ... my answer below ...
> My key to understanding was noticing that the only usage
> of 'pdbAddr' is to print the record name:
> > printf(" %s\n",pdbAddr->precord->name);
> Now the most obvious answer would be if the struct dbAddr
> embedded in the struct dbChannel were the first member.
> However, this is not the case.
> > typedef struct dbChannel {
> > const char *name; /**< Channel name */
> > dbAddr addr; /**< Pointers to record & field */
> The first member of dbAddr is the record pointer:
> > typedef struct dbAddr {
> > struct dbCommon *precord; /* address of record */
> So
> was actually accessing dbChannel::name with the correct
> number of indirections (1) because 'precord->name' is not
> actually an indirection since the first member is a 'char[]'.
> > typedef struct dbCommon {
> > char name[61]; /**< @brief Record Name */
> So, I wasn't entirely truthful in calling this a no-op.
> If a DB_LINK were targeted at a record alias name, then
> between 3.15.0.1 and now, dblsr() would print the alias
> instead of the intended canonical record name.
> Now for the weekend!
- dblsr code question/challenge Michael Davidsaver via Core-talk
Build completed: EPICS Base 7 base-7.0-1174 AppVeyor via Core-talk
Build failed: EPICS Base 7 base-7.0-1191 AppVeyor via Core-talk
<2024>
2025
2026
Re: dblsr code question/challenge Kasemir, Kay via Core-talk
<2024>
2025
2026
