2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: Windows misbehavior compiling Base (toolchain.c ?)
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: Ralph Lange <ralph.lange at gmx.de>, EPICS Core Talk <core-talk at aps.anl.gov>
Date: Fri, 10 Jan 2025 17:13:11 +0000
I just restarted the build of this PR after downloading the full build log of the one job that failed after 1 hr:
Build EPICS Base 7 base-7.0-1411 failed
Commit 43d6ed95f2 by Jeremy Lorelli on 12/22/2024 8:25 PM:
Add EPICS_DIAGNOSE_AS attribute for clang
The symptoms look different but may be related: In this case toolchain.c was successfully built, but despite the job being stopped after the 1hr the last entry in the log was at 00:19:36.
[00:01:08] ===== \/ \/ \/ ===== START: Build the main module =====
[00:01:08] make -C ./configure install
[00:01:09] make[1]: Entering directory 'C:/projects/epics-base/configure'
[00:01:09] perl -CSD ../src/tools/makeMakefile.pl O.windows-x64-static ../..
[00:01:09] make[1]: Leaving directory 'C:/projects/epics-base/configure'
[00:01:09] perl -CSD -MExtUtils::Command -e mkpath O.Common
[00:01:09] make -C O.windows-x64-static -f ../Makefile TOP=../.. \
[00:01:09]     T_A=windows-x64-static install
[00:01:12] make[2]: Entering directory 'C:/projects/epics-base/configure/O.windows-x64-static'
[00:01:12] cl -nologo -C -E               -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE  -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include         ../toolchain.c > TOOLCHAIN.windows-x64-static.windows-x64-static
[00:01:12] toolchain.c
[00:01:12] make[2]: Leaving directory 'C:/projects/epics-base/configure/O.windows-x64-static'
[00:01:12] Installing CFG file ../../cfg/TOOLCHAIN.windows-x64-static.windows-x64-static
[00:01:12] mkdir ../../cfg
[00:19:36] make[4]: Entering directory 'C:/projects/epics-base/modules/pva2pva/pdbApp/O.windows-x64-static'
[00:19:36] cl -EHsc -GR           -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"C:/projects/epics-base\"" -DNOMINMAX     -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE    -Ox -Oy-   -W3 -w44355 -w44344 -w44251 -D_SILENCE_TR1_NAMESPACE_DEPRECATION_WARNING        -MT  -TP  -I. -I../O.Common -I. -I. -I.. -IC:/projects/epics-base/include/compiler/msvc -IC:/projects/epics-base/include/os/WIN32 -IC:/projects/epics-base/include -IC:/projects/epics-base/include/compiler/msvc -IC:/projects/epics-base/include/os/WIN32 -IC:/projects/epics-base/include        -c ../softMain.cpp
[00:19:36] softMain.cpp
[00:19:36] make[4]: Leaving directory 'C:/projects/epics-base/modules/pva2pva/pdbApp/O.windows-x64-static'
[00:19:36] cl -EHsc -GR           -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"C:/projects/epics-base\"" -DNOMINMAX     -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE    -Ox -Oy-   -W3 -w44355 -w44344 -w44251 -D_SILENCE_TR1_NAMESPACE_DEPRECATION_WARNING        -MT  -TP  -I. -I../O.Common -I. -I. -I.. -IC:/projects/epics-base/include/compiler/msvc -IC:/projects/epics-base/include/os/WIN32 -IC:/projects/epics-base/include -IC:/projects/epics-base/include/compiler/msvc -IC:/projects/epics-base/include/os/WIN32 -IC:/projects/epics-base/include        -c softIocPVA_registerRecordDeviceDriver.cpp
[00:19:36] softIocPVA_registerRecordDeviceDriver.cpp
Note that our CI log-files don’t include any command(s) which hang, and even making the build verbose probably won’t fix that. We give GnuMake the flags --j<n>  --output-sync=target which only logs the commands it executed and their output after they are done, either successfully or by failing. Another build follows the above line with this linker command to create the qsrv.lib so that might be the cause here:
[00:19:58] make[4]: Entering directory 'C:/projects/epics-base/modules/pva2pva/pdbApp/O.windows-x64-static'
[00:19:58] lib -nologo -verbose -out:qsrv.lib    pvif.obj qsrv.obj pdb.obj pdbsingle.obj demo.obj imagedemo.obj pdbgroup.obj configparse.obj dbf_copy.obj tpool.obj pvalink.obj pvalink_lset.obj pvalink_jlif.obj pvalink_link.obj pvalink_channel.obj
[00:19:58] Appending pvalink_channel.obj
[00:19:58] Appending pvalink_link.obj
[00:19:58] Appending pvalink_jlif.obj
[00:19:58] Appending pvalink_lset.obj
[00:19:58] Appending pvalink.obj
[00:19:58] Appending tpool.obj
[00:19:58] Appending dbf_copy.obj
[00:19:58] Appending configparse.obj
[00:19:58] Appending pdbgroup.obj
[00:19:58] Appending imagedemo.obj
[00:19:58] Appending demo.obj
[00:19:58] Appending pdbsingle.obj
[00:19:58] Appending pdb.obj
[00:19:58] Appending qsrv.obj
[00:19:58] Appending pvif.obj
[00:19:58] make[4]: Leaving directory 'C:/projects/epics-base/modules/pva2pva/pdbApp/O.windows-x64-static'
[00:19:58] Installing library C:/projects/epics-base/lib/windows-x64-static/qsrv.lib
Just another $0.02 with further evidence.
- Andrew
Complexity comes for free, Simplicity you have to work for.
On 1/8/25, 2:00AM, "Core-talk" <core-talk-bounces at aps.anl.gov> wrote:
Dear colleagues,
Working on a feature branch for ci-scripts, I am puzzled about failing AppVeyor builds, e.g.
where a large number of VisualStudio builds are consistently getting stuck in Base at or after compiling 'toolchain.c'.
I repeated the build a few times - this is a hard issue.
Does anyone have an idea what could be going on?
Clueless,
~Ralph
Re: Windows misbehavior compiling Base (toolchain.c ?) Ralph Lange via Core-talk
Prev: Build failed: EPICS Base 7 base-7.0-1411 AppVeyor via Core-talk
Next: Build failed: pva2pva 1.0.55 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: Re: Windows misbehavior compiling Base (toolchain.c ?) Zimoch Dirk via Core-talk
Next: Re: Windows misbehavior compiling Base (toolchain.c ?) Ralph Lange via Core-talk
ANJ, 11 Jan 2025 · Home · News · About · Talk · Base · Modules · Extensions ·
