2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Did the "Fedora-latest" version on GitHub just get bumped?
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: EPICS core-talk <core-talk at aps.anl.gov>
Date: Wed, 16 Apr 2025 16:34:52 +0000
I saw that a new Fedora was release very recently.
Dirk’s latest PR failed to build the main module on that job (which says it’s using gcc 15) with the error below:
make[5]: Entering directory '/__w/epics-base/epics-base/modules/database/src/ioc/O.linux-x86_64'
4675 gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -fdiagnostics-color -DUSE_TYPED_RSET -DUSE_TYPED_DSET -D_X86_64_ -DUNIX -Dlinux -DBUILDING_dbCore_API -O3 -g -Wall -Werror-implicit-function-declaration -DUSE_TYPED_DRVET -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include -c ../dbStatic/dbStaticLib.c
4676 make[5]: Leaving directory '/__w/epics-base/epics-base/modules/database/src/ioc/O.linux-x86_64'
4677 ../dbStatic/dbStaticLib.c:3459:36: error: initialization of ‘long int (**)(void)’ from incompatible pointer type ‘long int (**)(int)’ [-Wincompatible-pointer-types]
4678 3459 | DEVSUPFUN *pfunc = &pdevSup->pdset->report;
4679 | ^
4680 make[5]: *** [../../../../../configure/RULES_BUILD:260: dbStaticLib.o] Error 1
- Andrew
Complexity comes for free, Simplicity you have to work for.
Re: Did the "Fedora-latest" version on GitHub just get bumped? Zimoch Dirk via Core-talk
Re: Did the "Fedora-latest" version on GitHub just get bumped? Michael Davidsaver via Core-talk
Prev: Build failed: EPICS Base 7 base-7.0-1619 AppVeyor via Core-talk
Next: Re: Did the "Fedora-latest" version on GitHub just get bumped? Zimoch Dirk via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
ANJ, 17 Apr 2025 · Home · News · About · Talk · Base · Modules · Extensions ·
