The bug that I fixed was introduced in the mentioned merge, which was
after 3.14.11 was branched off.
Reason:
The line incrementing the iiuExistenceCount was added to cac.cpp after
the revision that ca-over-tcp was originally based upon.
That particular code block (containing the increment) was refactored by
ca-over-tcp into a separate function - that way it slipped through the
merge, as that new function was not present in the pre-merge revision,
and the (changed) code to compare the new function against was in a
different location in the file.
The organized teardown is the only thing the iiuExistenceCount is used
for. So I'd say the current version (using the fix that I sent earlier)
is more obvious than the original code - as it sets the
iiuExistenceCount in the method that uses it.
Probably a personal preference, though.
Ralph
On 16.08.2010 13:00, Kasemir, Kay wrote:
Hi Ralph:
We're using 3.14.11, and I wonder if this patch is also needed for us.
In our sources, the
// shutdown all tcp circuits
is around line 1230 of our src/ca/cac.cpp, not line 287 as in your email.
It does look like the iiuExistenceCount is incremented and decremented in
our code, but I don't try to understand if it's inc'ed/dec'ed correctly.
So is this a patch that only applies to recent ca-over-tcp additions, not
the plain 3.14.11?
Kay
------ Forwarded Message
Date: Mon, 16 Aug 2010 12:03:10 -0400
To: Andrew Johnson<[email protected]>
Cc: EPICS Core Talk<[email protected]>
Subject: Fixed: Segfaults in 3.14 branch since merging ca-over-tcp
Hi Andrew,
it looks as I have found the reason for the segfaults, which I think is
a bug in CAC.
In the cac::~cac() destructor, a private member
"this->iiuExistenceCount" is used to determine if cac should wait for
TCP threads to shutdown. While this counter gets correctly decreased in
cac::destroyIIU(), it never gets increased or set (except initialized to
0 in the cpp constructor).
So cac::~cac() was neve/r waiting for the TCP threads to shutdown, and
happily kept tearing down the timer/mutex infrastructure. If the threads
were not fast enough, they were hitting on destroyed semaphores when
cancelling their watchdog timers - that was causing the exceptions and
segfaults.
This one-line fix will take care of the problem:
=== modified file 'src/ca/cac.cpp'
--- src/ca/cac.cpp 2010-04-15 21:06:16 +0000
+++ src/ca/cac.cpp 2010-08-16 15:24:13 +0000
@@ -287,6 +287,7 @@
+ this->iiuExistenceCount = this->circuitList.count();
tsDLIter< tcpiiu> iter = this->circuitList.firstIter ();
while ( iter.valid() ) {
// this causes a clean shutdown to occur
Maybe it actually takes care of several shutdown related issues...
Yay!
Ralph
------ End of Forwarded Message
- Re: FW: Fixed: Segfaults in 3.14 branch since merging ca-over-tcp Andrew Johnson
Re: Fixed: Segfaults in 3.14 branch since merging ca-over-tcp Andrew Johnson
<2010>
2025
Re: Fixed: Segfaults in 3.14 branch since merging ca-over-tcp Ralph Lange
<2010>
2025
