On 17.08.2010 21:00, Jeff Hill wrote:
Looks like a potential issue.
option 1)
You might insert "this->chanTable.removeAll ()" after line 295 in ~cac
which will cause cac::transferChanToVirtCircuit to noop return at line
583. You would need to supply a temporary (auto) tsSLList<T> target to
removeAll but could safely ignore
option 2)
Just add a bool flag to cac as you propose, set it just after line 295
in ~cac, and check it at the beginning of cac::transferChanToVirtCircuit.
It would also need to be initialized in the cac ctor. Of course the set
and test will need to be protected by a Guard. The downside is that
this requires slightly more memory at runtime, but this is no-doubt
insignificant. Perhaps the only downside is needing to remember the
purpose of yet another binary flag a few years down the road.
I'll go with the simple approach.
This is a one-way communication, so a proper set-and-test is not necessary.
I will set the flag (under the lock) at the beginning of the cac dtor
and check it (under the lock) at the beginning of
cac::transferChanToVirtCircuit - that should do it.
I think a comment will reliably remove the need to remember the purpose
of the flag. ;-)
Thanks for your help!
Ralph
- Fixed: Segfaults in 3.14 branch since merging ca-over-tcp Ralph Lange
- RE: Fixed: Segfaults in 3.14 branch since merging ca-over-tcp Jeff Hill
- Re: Fixed: Segfaults in 3.14 branch since merging ca-over-tcp Ralph Lange
Re: Bazaar commit messages: style guide Ralph Lange
<2010>
2025
Re: FW: Fixed: Segfaults in 3.14 branch since merging ca-over-tcp Ralph Lange
<2010>
2025
