On Freitag, 29. Oktober 2010, Andrew Johnson wrote:
> On Friday 29 October 2010 14:15:54 Ralph Lange wrote:
> > On 29.10.2010 15:10, Eric Norum wrote:
> > > +dded to epicsEventTest and the application developers guide has
> > > been updated +to describe this requirement.</p>
> > Did you actually update the guide? At least I don't see it on
> > launchpad yet...
> Working on it, I have some uncommitted formatting changes that I want
> to keep separate that I'm also dealing with.
While you're at it, please fix the description for wait and tryWait,
they are most probably wrong. What is returned is an
epicsEventWaitStatus, not boolean. When interpreted as boolean the
return value is zero (false) if the event *did* happen
(epicsEventWaitOK) and non-zero (true) if it did not happen
(epicsEventWaitTimeout) or if an error happened (epicsEventWaitError).
At least this is what the names suggest.
Cheers
Ben
- Re: epicsEvent semantics Ben Franksen
- epicsEvent semantics Eric Norum
- Re: epicsEvent semantics Ralph Lange
- Re: epicsEvent semantics Andrew Johnson
<2010>
2025
<2010>
2025
