2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: epicsEvent semantics
To: [email protected]
Date: Sat, 30 Oct 2010 03:48:45 +0200
On Samstag, 30. Oktober 2010, Ben Franksen wrote:
> On Freitag, 29. Oktober 2010, Andrew Johnson wrote:
> > On Friday 29 October 2010 14:15:54 Ralph Lange wrote:
> > >   On 29.10.2010 15:10, Eric Norum wrote:
> > > > +dded to epicsEventTest and the application developers guide
> > > > has been updated +to describe this requirement.</p>
> > > Did you actually update the guide? At least I don't see it on
> > > launchpad yet...
> > Working on it, I have some uncommitted formatting changes that I
> > want to keep separate that I'm also dealing with.
> While you're at it, please fix the description for wait and tryWait,
> they are most probably wrong. What is returned is an
> epicsEventWaitStatus, not boolean. When interpreted as boolean the
> return value is zero (false) if the event *did* happen
> (epicsEventWaitOK) and non-zero (true) if it did not happen
> (epicsEventWaitTimeout) or if an error happened
> (epicsEventWaitError). At least this is what the names suggest.
Oops. I have not looked close enough. The C and C++ interfaces differ in
the return value. The C++ methods really return bool, whereas the C
routines return the epicsEventWaitStatus. Am I the only one who finds
this confusing? What happens if the C++ method encounters an error?
Cheers
ben
Re: epicsEvent semantics Andrew Johnson
RE: epicsEvent semantics Jeff Hill
epicsEvent semantics Eric Norum
Re: epicsEvent semantics Ben Franksen
Prev: Re: epicsEvent semantics Ben Franksen
Next: Re: epicsEvent semantics Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
