2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Base R3.16.0.1 ?
To: [email protected]
Date: Mon, 29 Feb 2016 21:56:08 -0500
On 02/29/2016 07:18 PM, Andrew Johnson wrote:
> I think I just merged & committed the last thing I can think of that we
> have ready for 3.16.0.1, have I missed anything? The remaining merges
> still need work, and I think I looked at all of the bugs with patches;
> did I miss anything?
I don't think so.  I see what I was expecting.
I locally merged [1] and ran the tests for RTEMS-pc386.  Found and fixed
a problem with recordTestHarness.
When running tests individually I found that epicsTimeZoneTest isn't
included the libComTestHarness though it probably should be.  However, I
didn't add it yet as it doesn't pass w/ RTEMS 4.9 due to problems with
TZ=UTC cases.
> src/libCom/test/O.RTEMS-pc386/epicsTimeZoneTest.tap:not ok 24 - hour 8==13
> src/libCom/test/O.RTEMS-pc386/epicsTimeZoneTest.tap:not ok 30 - isdst 1==0
> src/libCom/test/O.RTEMS-pc386/epicsTimeZoneTest.tap:not ok 64 - hour 8==14
[1] https://code.launchpad.net/~epics-core/epics-base/test-rtems-w-qemu
Re: Base R3.16.0.1 ? Johnson, Andrew N.
Base R3.16.0.1 ? Andrew Johnson
Prev: Build failed in Jenkins: epics-base-3.16-win32-test #27 APS Jenkins
Next: Jenkins build is back to normal : epics-base-3.16-win32-test #28 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Base R3.16.0.1 ? Andrew Johnson
Next: Re: Base R3.16.0.1 ? Johnson, Andrew N.
ANJ, 01 Mar 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
