2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Base R3.16.0.1 ?
To: Michael Davidsaver <[email protected]>
Date: Tue, 1 Mar 2016 23:12:05 +0000
I have 2 installations of Cygwin, versions 1.7.30 and 2.0.0 on different PCs. One of them (v2.0.0) is giving me "Duplicate EPICS CA Address list entry" errors from libca on startup of the softIoc from either 3.15 or 3.16. The other does not. I'm fairly sure this is since merging the rsrvbindiface branch, was this one of the issues Ralph was seeing?
- Andrew
Sent from my iPad
> On Feb 29, 2016, at 8:56 PM, Michael Davidsaver <[email protected]> wrote:
>> On 02/29/2016 07:18 PM, Andrew Johnson wrote:
>> I think I just merged & committed the last thing I can think of that we
>> have ready for 3.16.0.1, have I missed anything? The remaining merges
>> still need work, and I think I looked at all of the bugs with patches;
>> did I miss anything?
> I don't think so.  I see what I was expecting.
> I locally merged [1] and ran the tests for RTEMS-pc386.  Found and fixed
> a problem with recordTestHarness.
> When running tests individually I found that epicsTimeZoneTest isn't
> included the libComTestHarness though it probably should be.  However, I
> didn't add it yet as it doesn't pass w/ RTEMS 4.9 due to problems with
> TZ=UTC cases.
>> src/libCom/test/O.RTEMS-pc386/epicsTimeZoneTest.tap:not ok 24 - hour 8==13
>> src/libCom/test/O.RTEMS-pc386/epicsTimeZoneTest.tap:not ok 30 - isdst 1==0
>> src/libCom/test/O.RTEMS-pc386/epicsTimeZoneTest.tap:not ok 64 - hour 8==14
> [1] https://code.launchpad.net/~epics-core/epics-base/test-rtems-w-qemu
Re: Base R3.16.0.1 ? Michael Davidsaver
Base R3.16.0.1 ? Andrew Johnson
Prev: Jenkins build is back to normal : epics-base-3.15-win32-test #34 APS Jenkins
Next: Re: Base R3.16.0.1 ? Michael Davidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Base R3.16.0.1 ? Michael Davidsaver
ANJ, 01 Mar 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
