2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Base R3.16.0.1 ?
To: "Johnson, Andrew N." <[email protected]>
Date: Tue, 1 Mar 2016 18:18:02 -0500
On 03/01/2016 06:12 PM, Johnson, Andrew N. wrote:
> I have 2 installations of Cygwin, versions 1.7.30 and 2.0.0 on different PCs. One of them (v2.0.0) is giving me "Duplicate EPICS CA Address list entry" errors from libca on startup of the softIoc from either 3.15 or 3.16. The other does not. I'm fairly sure this is since merging the rsrvbindiface branch, was this one of the issues Ralph was seeing?
This warning is printed by removeDuplicateAddresses(), which is used by
the CA client and both server implementations.  The fact that it says
"EPICS CA Address list" has always been deceptive as it is used for all
types of address lists (beacons and now interfaces).  You'll probably
have to run in a debugger to find which call site is giving the warning.
Re: Base R3.16.0.1 ? Andrew Johnson
Re: Base R3.16.0.1 ? Michael Davidsaver
Re: Base R3.16.0.1 ? Johnson, Andrew N.
Prev: Re: Base R3.16.0.1 ? Johnson, Andrew N.
Next: Build failed in Jenkins: epics-base-3.16-win32-test #30 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Base R3.16.0.1 ? Andrew Johnson
ANJ, 02 Mar 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
