2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Errors when running "make -sj clean" on windows-x64 in top-level of pvPackageCPP
To: "'Andrew Johnson'" <[email protected]>, "'EPICS core-talk'" <[email protected]>
Date: Thu, 8 Sep 2016 14:28:11 +0000
Hi Andrew,
I get the following errors when running  "make -sj clean" on windows-x64 in top-level of pvPackageCPP
H:\epics\pvPackageCPP-3.15>make -sj clean
cannot remove directory for ./include: Permission denied at C:/Perl64/lib/ExtUtils/Command.pm line 134
cannot remove directory for lib\linux-x86: Directory not empty at C:/Perl64/lib/ExtUtils/Command.pm line 134
cannot remove directory for ./lib: Directory not empty at C:/Perl64/lib/ExtUtils/Command.pm line 134
I would also really like to be able to do “make realclean” and “make realuninstall” in that top-level directory, but that is not supported.
Note that this is the version of pvPackageCPP I downloaded from the link in an e-mail you sent a few weeks ago, and not the current release candidate for the CPP modules.
Re: Errors when running "make -sj clean" on windows-x64 in top-level of pvPackageCPP Johnson, Andrew N.
Prev: RE: Fix for building 3.15.4 on windows-x64-static Mark Rivers
Next: Re: Fix for building 3.15.4 on windows-x64-static Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to normal : epics-base-3.16-mac-test #65 APS Jenkins
Next: Re: Errors when running "make -sj clean" on windows-x64 in top-level of pvPackageCPP Johnson, Andrew N.
ANJ, 18 Sep 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
