2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Fix for building 3.15.4 on windows-x64-static
To: <[email protected]>
Date: Thu, 8 Sep 2016 10:33:59 -0500
On 09/08/2016 09:20 AM, Mark Rivers wrote:
> Searching for the presence of "Visual Studio 10.0" in the PATH
> environment variable might work.
If the build system really needs to know which compiler version it's
using I would much rather we have the user tell it that in their
CONFIG_SITE.Common.win* file(s). The build system has to run any kind of
per-compiler test every time it reads a Makefile, and calling out to a
Perl script to do this kind of test every time is probably going to slow
the build measurably.
On the other hand doing this kind of thing using the pre-processor and a
#pragma optimize() setting is fast and localized, so I would much prefer
that we stick with that solution if it can do what we need. You can tell
whether you're building a dynamic binary there by the presence of the
EPICS_BUILD_DLL macro.
- Andrew
Re: Fix for building 3.15.4 on windows-x64-static Andrew Johnson
RE: Fix for building 3.15.4 on windows-x64-static Mark Rivers
Re: Fix for building 3.15.4 on windows-x64-static Ralph Lange
Prev: Errors when running "make -sj clean" on windows-x64 in top-level of pvPackageCPP Mark Rivers
Next: Re: Fix for building 3.15.4 on windows-x64-static Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Fix for building 3.15.4 on windows-x64-static Mark Rivers
ANJ, 08 Sep 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
