2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Errors when running "make -sj clean" on windows-x64 in top-level of pvPackageCPP
To: "Rivers, Mark L." <[email protected]>
Cc: EPICS core-talk <[email protected]>
Date: Mon, 19 Sep 2016 11:57:21 +0000
You can use "make -sj host" to parallel-build just the host architecture (i.e. $EPICS_HOST_ARCH). The host target also exists in Base-3.15 BTW, but not in 3.14.
Integration will be better in EPICS 7.
- Andrew
Sent from my iPad
> On Sep 18, 2016, at 11:17 PM, Mark Rivers <[email protected]> wrote:
> It might be nice to have a top-level script that checks out the tags for each submodule for a given top-level release.
> I just found that it is not possible to issue this command at the top-level:
> make install.linux-x86
> That is a bit of a pain.  I can use the -j option on linux-x86 and win32-x86-mingw-static, but not with win32-x86-mingw.  I am cross-compiling the mingw builds.  So I would like to run the first 2 architectures with -j and then the third architecture without -j.  But I cannot do that.
> Thanks,
> Mark
> From: Johnson, Andrew N. [[email protected]]
> Sent: Sunday, September 18, 2016 10:12 PM
> To: Mark Rivers
> Cc: EPICS core-talk
>> What command do I issue in the top-level repository to ensure that all submodules are at the correct version for 4.6.0 of the top-level?
> You may be able to say
>    git submodule update
> but I'm not sure if that always works. You can do
>    git submodule status
> and you'll get a list of the states of the submodules and compare them with the contents of the documentation/git-versions file to be sure, but you might have to go into any submodule that is not correctly checked out and do a
>    git checkout 4.2.2
> or similar depending on the tag to fix it.
> - Andrew
> Sent from my iPad
Errors when running "make -sj clean" on windows-x64 in top-level of pvPackageCPP Mark Rivers
Re: Errors when running "make -sj clean" on windows-x64 in top-level of pvPackageCPP Johnson, Andrew N.
RE: Errors when running "make -sj clean" on windows-x64 in top-level of pvPackageCPP Mark Rivers
Prev: RE: Errors when running "make -sj clean" on windows-x64 in top-level of pvPackageCPP Mark Rivers
Next: Time issues on Linux Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Errors when running "make -sj clean" on windows-x64 in top-level of pvPackageCPP Johnson, Andrew N.
ANJ, 27 Sep 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
