2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c
From: "Williams Jr., Ernest L." <[email protected]>
To: Andrew Johnson <[email protected]>, Michael Davidsaver <[email protected]>, Heinz Junkes <[email protected]>, "[email protected]" <[email protected]>
Cc: "Slepicka, Hugo Henrique" <[email protected]>
Date: Sat, 19 Aug 2017 03:30:39 +0000
Hi Guys,
I am experiencing the same issue with EPICS R3.15.5 and RTEMS version "4.9.4"
Can you add the patch to the KnownProblems page?
http://www.aps.anl.gov/epics/base/R3-15/5-docs/KnownProblems.html
Cheers,
Ernest Williams
Dept. Head, Advanced Control Systems
Advanced Instrumentation Research, Technology Innovation Directorate
SLAC National Laboratory, Stanford University
From: [email protected] [[email protected]] on behalf of Andrew Johnson [[email protected]]
Sent: Thursday, April 20, 2017 9:21 AM
To: Michael Davidsaver; Heinz Junkes; [email protected]
Subject: Re: RTEMS: rsrv: failed to set mcast loopback in       src/ioc/rsrv/caservertask.c
On 04/20/2017 10:19 AM, Michael Davidsaver wrote:
> I see that linux (circa 3.16) will accept either 'int' or 'char' for
> IP_MULTICAST_LOOP.  Also for most other integer flags.
> I find references which suggest that winsock wants BOOL (which I assume
> is 'char').
> However, vxworks 5.5 clearly spec's 'int'.
> http://www.vxdev.com/docs/vx55man/vxworks/ref/sockLib.html
But as long as we're talking about Base-3.16 we don't have to support
VxWorks 5.5 at all. Wind River completely replaced the network stack in
VxWorks 6.x, and the newer stack looks like it will support either int
or char (there's code in setsockopt() for IP_MULTICAST_LOOP which
appears to handle both sizes, although they haven't updated the docs to
actually say that).
> Seems like the IP_MULTI* socket options need unit-test coverage.  (maybe
> add to blockingSocketTest.cpp ?)
Agreed, and that seems like the right place for it.
- Andrew
Re: RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Andrew Johnson
RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Heinz Junkes
Re: RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Heinz Junkes
Re: RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Michael Davidsaver
Prev: RE: epicsStackTrace on WIN32 freddie.akeroyd
Next: Add optimization switch to compiler dependencies Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Andrew Johnson
Next: Re: RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Andrew Johnson
