2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: base-3.16.1 bug
To: Michael Davidsaver <[email protected]>, Ralph Lange <[email protected]>
Cc: EPICS Core Talk <[email protected]>
Date: Wed, 6 Sep 2017 18:17:07 -0500
On 09/06/2017 12:12 PM, Michael Davidsaver wrote:
> @Andrew Will you be adding a test to trigger this regression before
> fixing it?  src/std/rec/test/regressTest.c would be a easy place.
I had already started creating a new softTest program, analogous to the
asyncSoftTest code already under std/rec/test. Will finish off tomorrow.
>> I would say the dummy method returning OK is the way to go. Other link
>> types might return errors that are worth reporting, and it is certainly
>> a property of the CONSTANT link that a put() operation is never
>> producing an error.
> I agree with this.
Thanks for responding.
> Another inconsistency.  CA put w/ callback is losing the error.  I see
> that dbNotify ignores the result of dbProcess().  It would be nice if it
> didn't...
That's a whole other level of complexity, the result would have to be
saved in the processNotify object by dbNotify and then retrieved and
returned to the client by the rsrv callback routine — the first part is
easy, but the second isn't obvious...
> I also noticed that dbNotify doesn't propagate some errors in it's
> putCallback for link fields.
Similar, I think that's a different bug (and I shouldn't really have
been spending time writing tests for the original problem at the moment,
but I did).
- Andrew
Re: base-3.16.1 bug Andrew Johnson
Re: base-3.16.1 bug Ralph Lange
Re: base-3.16.1 bug Michael Davidsaver
Prev: Re: base-3.16.1 bug Michael Davidsaver
Next: Re: base-3.16.1 bug Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
