2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: pva2pva build on APS Jenkins
Cc: EPICS core-talk <[email protected]>
Date: Tue, 17 Oct 2017 16:27:02 -0500
Right, I forgot about this.  This has to do with use of the 'auto'
keyword, or GCC specific '__typeof__'.  See p2pApp/helper.h
Removing this requirement mostly means making a lot of iterator loops
ugly (see FOREACH macro).
On 10/17/2017 04:00 PM, Andrew Johnson wrote:
> Hi Michael,
> I just created a win64 build of pva2pva on the APS Jenkins, which is
> using the MSVC++ compiler. It fails with fatal errors:
>> p2pApp\helper.h(15) : fatal error C1189: #error :  Require C++11 or G++
> Note that I'm using 'make -O -j4' so there may be other compiler errors
> also visible in the full build log at
> https://jenkins.aps.anl.gov/view/EPICS%20V4/job/3.15-pva2pva-win64/lastBuild/console
> I'm not using a particularly recent version (Visual Studio 10.0), but
> this is the first place I've see that error. If this would hard to fix I
> do have newer compilers available, but we should document the minimum
> required MS compiler version.
> - Andrew
pva2pva build on APS Jenkins Andrew Johnson
Prev: pva2pva build on APS Jenkins Andrew Johnson
Next: Build failed in Jenkins: epics-base-3.15-sol #105 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
