See <https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/105/display/redirect?page=changes>
Changes:
[Andrew Johnson] Add osiSockOptMcastLoop_t and osiSockTest
[Andrew Johnson] More tests, check both true and false values for options.
[Andrew Johnson] libcom/test: osiSockTest fix for RTEMS
[Andrew Johnson] Release Notes
[Andrew Johnson] Unify rsrv socket errors, add missing error string
[...truncated 280.09 KB...]
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include -c ../../../src/libCom/osi/os/posix/osdMutex.c
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include -c ../../../src/libCom/osi/os/posix/osdSpin.c
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include -c ../../../src/libCom/osi/os/posix/osdEvent.c
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include -c ../../../src/libCom/osi/os/posix/osdTime.cpp
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include -c ../../../src/libCom/osi/os/posix/osdProcess.c
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include -c ../../../src/libCom/osi/os/default/osdNetIntf.c
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include -c ../../../src/libCom/osi/os/default/osdMessageQueue.cpp
"../../../src/libCom/osi/os/default/osdMessageQueue.cpp", line 195: Warning: status hides the same name in an outer scope.
"../../../src/libCom/osi/os/default/osdMessageQueue.cpp", line 344: Warning: status hides the same name in an outer scope.
2 Warning(s) detected.
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include -c ../../../src/libCom/osi/devLibVME.c
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include -c ../../../src/libCom/osi/os/default/devLibVMEOSD.c
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include -c ../../../src/libCom/osi/epicsStackTrace.c
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include -c ../../../src/libCom/osi/os/solaris/osdBackTrace.cpp
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include -c ../../../src/libCom/osi/os/solaris/osdFindAddr.c
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include -c ../../../src/libCom/pool/poolJob.c
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include -c ../../../src/libCom/pool/threadPool.c
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include -c ../../../src/libCom/ring/epicsRingPointer.cpp
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include -c ../../../src/libCom/ring/epicsRingBytes.c
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include -c ../../../src/libCom/taskwd/taskwd.c
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include -c ../../../src/libCom/timer/epicsTimer.cpp
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include -c ../../../src/libCom/timer/timer.cpp
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include -c ../../../src/libCom/timer/timerQueue.cpp
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include -c ../../../src/libCom/timer/timerQueueActive.cpp
"../../../src/libCom/timer/timerQueueActive.cpp", line 26: Warning: Could not find source for epicsSingleton<timerQueueActiveMgr>::epicsSingleton(const epicsSingleton<timerQueueActiveMgr>&).
"../../../src/libCom/timer/timerQueueActive.cpp", line 26: Warning: Could not find source for epicsSingleton<timerQueueActiveMgr>::operator=(const epicsSingleton<timerQueueActiveMgr>&).
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include -c ../../../src/libCom/timer/timerQueueActiveMgr.cpp
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include -c ../../../src/libCom/timer/timerQueuePassive.cpp
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include -c ../../../src/libCom/yajl/yajl.c
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include -c ../../../src/libCom/yajl/yajl_alloc.c
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include -c ../../../src/libCom/yajl/yajl_buf.c
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include -c ../../../src/libCom/yajl/yajl_encode.c
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include -c ../../../src/libCom/yajl/yajl_gen.c
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include -c ../../../src/libCom/yajl/yajl_lex.c
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include -c ../../../src/libCom/yajl/yajl_parser.c
/opt/SUNWspro/bin/CC -xar -o libCom.a asLib.o asTrapWrite.o bucketLib.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsOnce.o epicsSingletonMutex.o dbmf.o ellLib.o ellSort.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o alarmString.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsMath.o epicsAtomicOSD.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdThreadExtra.o osdThreadHooks.o osdMutex.o osdSpin.o osdEvent.o osdTime.o osdProcess.o osdNetIntf.o osdMessageQueue.o devLibVME.o devLibVMEOSD.o epicsStackTrace.o osdBackTrace.o osdFindAddr.o poolJob.o threadPool.o epicsRingPointer.o epicsRingBytes.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o yajl.o yajl_alloc.o yajl_buf.o yajl_encode.o yajl_gen.o yajl_lex.o yajl_parser.o
/opt/SUNWspro/bin/CC -o libCom.so.3.15.5 -z defs -G -h libCom.so.3.15.5 -z text -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -mt -z ignore -z combreloc -z lazyload asLib.o asTrapWrite.o bucketLib.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsOnce.o epicsSingletonMutex.o dbmf.o ellLib.o ellSort.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o alarmString.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsMath.o epicsAtomicOSD.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdThreadExtra.o osdThreadHooks.o osdMutex.o osdSpin.o osdEvent.o osdTime.o osdProcess.o osdNetIntf.o osdMessageQueue.o devLibVME.o devLibVMEOSD.o epicsStackTrace.o osdBackTrace.o osdFindAddr.o poolJob.o threadPool.o epicsRingPointer.o epicsRingBytes.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o yajl.o yajl_alloc.o yajl_buf.o yajl_encode.o yajl_gen.o yajl_lex.o yajl_parser.o -lposix4 -lpthread -lm -lCstd -lsocket -lnsl -lumem -lCrun -lc
Installing shared library ../../../lib/solaris-sparc/libCom.so.3.15.5
mkdir ../../../lib/solaris-sparc
ln -s libCom.so.3.15.5 ../../../lib/solaris-sparc/libCom.so
Installing library ../../../lib/solaris-sparc/libCom.a
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include -c ../../../src/libCom/log/iocLogServer.c
/opt/SUNWspro/bin/CC -o iocLogServer -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -mt -z ignore -z combreloc -z lazyload iocLogServer.o -lCom -lsocket
Expanding ../../../src/libCom/log/S99logServer@ to S99logServer
Installing created executable ../../../bin/solaris-sparc/S99logServer
Installing created executable ../../../bin/solaris-sparc/iocLogServer
Installing html ../../../html/./freeList/freeList.html
mkdir ../../../html/./freeList
Installing html ../../../html/./gpHash/gpHash.html
mkdir ../../../html/./gpHash
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/src/libCom/O.solaris-sparc'>
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/src/libCom'>
make -C libCom/RTEMS install.solaris-sparc
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/src/libCom/RTEMS'>
perl -CSD <https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/bin/solaris-sparc/makeMakefile.pl> O.solaris-sparc ../../../..
mkdir O.Common
make -C O.solaris-sparc -f ../Makefile TOP=../../../.. \
T_A=solaris-sparc install
make[3]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/src/libCom/RTEMS/O.solaris-sparc'>
Installing generic include file ../../../../include/epicsRtemsInitHooks.h
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/src/libCom/RTEMS/O.solaris-sparc'>
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/src/libCom/RTEMS'>
make -C libCom/test install.solaris-sparc
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/src/libCom/test'>
mkdir O.Common
make[3]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/src/libCom/test/O.solaris-sparc'>
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > cvtFastPerform.d ../cvtFastPerform.cpp
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > epicsAtomicPerform.d ../epicsAtomicPerform.cpp
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > buckTest.d ../buckTest.c
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > epicsMaxThreads.d ../epicsMaxThreads.c
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > epicsThreadPerform.d ../epicsThreadPerform.cpp
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > osiSockTest.d ../osiSockTest.c
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > ipAddrToAsciiTest.d ../ipAddrToAsciiTest.cpp
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > epicsStackTraceTest.d ../epicsStackTraceTest.c
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > epicsMessageQueueTest.d ../epicsMessageQueueTest.cpp
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > blockingSockTest.d ../blockingSockTest.cpp
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > taskwdTest.d ../taskwdTest.c
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > macLibTest.d ../macLibTest.c
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > macDefExpandTest.d ../macDefExpandTest.c
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > epicsAtomicTest.d ../epicsAtomicTest.cpp
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > epicsSpinTest.d ../epicsSpinTest.c
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > epicsMutexTest.d ../epicsMutexTest.cpp
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > epicsEventTest.d ../epicsEventTest.cpp
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > ringBytesTest.d ../ringBytesTest.c
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > ringPointerTest.d ../ringPointerTest.c
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > epicsTimerTest.d ../epicsTimerTest.cpp
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > epicsExitTest.d ../epicsExitTest.c
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > epicsThreadPoolTest.d ../epicsThreadPoolTest.c
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > epicsThreadHooksTest.d ../epicsThreadHooksTest.c
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > epicsThreadPrivateTest.d ../epicsThreadPrivateTest.cpp
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > epicsThreadPriorityTest.d ../epicsThreadPriorityTest.cpp
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > epicsThreadOnceTest.d ../epicsThreadOnceTest.c
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > epicsThreadTest.d ../epicsThreadTest.cpp
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > epicsTimeZoneTest.d ../epicsTimeZoneTest.c
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > epicsTimeTest.d ../epicsTimeTest.cpp
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > epicsStringTest.d ../epicsStringTest.c
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > epicsSockResolveTest.d ../epicsSockResolveTest.c
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > epicsStdlibTest.d ../epicsStdlibTest.c
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > epicsStdioTest.d ../epicsStdioTest.c
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > epicsErrlogTest.d ../epicsErrlogTest.c
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > epicsEnvTest.d ../epicsEnvTest.c
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > epicsEllTest.d ../epicsEllTest.c
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > epicsMMIOTest.d ../epicsMMIOTest.c
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > epicsMathTest.d ../epicsMathTest.c
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > epicsAlgorithmTest.d ../epicsAlgorithmTest.cpp
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > epicsCalcTest.d ../epicsCalcTest.cpp
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > epicsInlineTest4.d ../epicsInlineTest4.cpp
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > epicsInlineTest3.d ../epicsInlineTest3.cpp
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > epicsInlineTest2.d ../epicsInlineTest2.c
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > epicsInlineTest1.d ../epicsInlineTest1.c
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > epicsTypesTest.d ../epicsTypesTest.c
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -xM1 > epicsUnitTestTest.d ../epicsUnitTestTest.c
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../epicsUnitTestTest.c
/opt/SUNWspro/bin/CC -o epicsUnitTestTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -mt -z ignore -z combreloc -z lazyload epicsUnitTestTest.o -lCom
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../epicsTypesTest.c
/opt/SUNWspro/bin/CC -o epicsTypesTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -mt -z ignore -z combreloc -z lazyload epicsTypesTest.o -lCom
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../epicsInlineTest1.c
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../epicsInlineTest2.c
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../epicsInlineTest3.cpp
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../epicsInlineTest4.cpp
/opt/SUNWspro/bin/CC -o epicsInlineTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -mt -z ignore -z combreloc -z lazyload epicsInlineTest1.o epicsInlineTest2.o epicsInlineTest3.o epicsInlineTest4.o -lCom
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../epicsCalcTest.cpp
/opt/SUNWspro/bin/CC -o epicsCalcTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -mt -z ignore -z combreloc -z lazyload epicsCalcTest.o -lCom
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../epicsAlgorithmTest.cpp
/opt/SUNWspro/bin/CC -o epicsAlgorithmTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -mt -z ignore -z combreloc -z lazyload epicsAlgorithmTest.o -lCom
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../epicsMathTest.c
/opt/SUNWspro/bin/CC -o epicsMathTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -mt -z ignore -z combreloc -z lazyload epicsMathTest.o -lCom
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../epicsMMIOTest.c
/opt/SUNWspro/bin/CC -o epicsMMIOTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -mt -z ignore -z combreloc -z lazyload epicsMMIOTest.o -lCom -lsocket
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../epicsEllTest.c
/opt/SUNWspro/bin/CC -o epicsEllTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -mt -z ignore -z combreloc -z lazyload epicsEllTest.o -lCom
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../epicsEnvTest.c
/opt/SUNWspro/bin/CC -o epicsEnvTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -mt -z ignore -z combreloc -z lazyload epicsEnvTest.o -lCom
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../epicsErrlogTest.c
/opt/SUNWspro/bin/CC -o epicsErrlogTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -mt -z ignore -z combreloc -z lazyload epicsErrlogTest.o -lCom -lsocket
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../epicsStdioTest.c
/opt/SUNWspro/bin/CC -o epicsStdioTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -mt -z ignore -z combreloc -z lazyload epicsStdioTest.o -lCom
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../epicsStdlibTest.c
/opt/SUNWspro/bin/CC -o epicsStdlibTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -mt -z ignore -z combreloc -z lazyload epicsStdlibTest.o -lCom
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../epicsSockResolveTest.c
/opt/SUNWspro/bin/CC -o epicsSockResolveTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -mt -z ignore -z combreloc -z lazyload epicsSockResolveTest.o -lCom -lsocket
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../epicsStringTest.c
/opt/SUNWspro/bin/CC -o epicsStringTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -mt -z ignore -z combreloc -z lazyload epicsStringTest.o -lCom
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../epicsTimeTest.cpp
/opt/SUNWspro/bin/CC -o epicsTimeTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -mt -z ignore -z combreloc -z lazyload epicsTimeTest.o -lCom
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../epicsTimeZoneTest.c
/opt/SUNWspro/bin/CC -o epicsTimeZoneTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -mt -z ignore -z combreloc -z lazyload epicsTimeZoneTest.o -lCom
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../epicsThreadTest.cpp
/opt/SUNWspro/bin/CC -o epicsThreadTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -mt -z ignore -z combreloc -z lazyload epicsThreadTest.o -lCom
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../epicsThreadOnceTest.c
/opt/SUNWspro/bin/CC -o epicsThreadOnceTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -mt -z ignore -z combreloc -z lazyload epicsThreadOnceTest.o -lCom
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../epicsThreadPriorityTest.cpp
/opt/SUNWspro/bin/CC -o epicsThreadPriorityTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -mt -z ignore -z combreloc -z lazyload epicsThreadPriorityTest.o -lCom
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../epicsThreadPrivateTest.cpp
/opt/SUNWspro/bin/CC -o epicsThreadPrivateTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -mt -z ignore -z combreloc -z lazyload epicsThreadPrivateTest.o -lCom
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../epicsThreadHooksTest.c
/opt/SUNWspro/bin/CC -o epicsThreadHooksTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -mt -z ignore -z combreloc -z lazyload epicsThreadHooksTest.o -lCom
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../epicsThreadPoolTest.c
/opt/SUNWspro/bin/CC -o epicsThreadPoolTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -mt -z ignore -z combreloc -z lazyload epicsThreadPoolTest.o -lCom
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../epicsExitTest.c
/opt/SUNWspro/bin/CC -o epicsExitTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -mt -z ignore -z combreloc -z lazyload epicsExitTest.o -lCom
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../epicsTimerTest.cpp
/opt/SUNWspro/bin/CC -o epicsTimerTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -mt -z ignore -z combreloc -z lazyload epicsTimerTest.o -lCom
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../ringPointerTest.c
/opt/SUNWspro/bin/CC -o ringPointerTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -mt -z ignore -z combreloc -z lazyload ringPointerTest.o -lCom
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../ringBytesTest.c
/opt/SUNWspro/bin/CC -o ringBytesTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -mt -z ignore -z combreloc -z lazyload ringBytesTest.o -lCom
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../epicsEventTest.cpp
/opt/SUNWspro/bin/CC -o epicsEventTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -mt -z ignore -z combreloc -z lazyload epicsEventTest.o -lCom
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../epicsMutexTest.cpp
/opt/SUNWspro/bin/CC -o epicsMutexTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -mt -z ignore -z combreloc -z lazyload epicsMutexTest.o -lCom
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../epicsSpinTest.c
/opt/SUNWspro/bin/CC -o epicsSpinTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -mt -z ignore -z combreloc -z lazyload epicsSpinTest.o -lCom
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../epicsAtomicTest.cpp
"../epicsAtomicTest.cpp", line 141: Warning (Anachronism): Formal argument funptr of type extern "C" void(*)(void*) in call to epicsThreadCreate(const char*, unsigned, unsigned, extern "C" void(*)(void*), void*) is being passed void(*)(void*).
"../epicsAtomicTest.cpp", line 239: Where: While instantiating "testIncrDecr<int>()".
"../epicsAtomicTest.cpp", line 239: Where: Instantiated from non-template code.
"../epicsAtomicTest.cpp", line 143: Warning (Anachronism): Formal argument funptr of type extern "C" void(*)(void*) in call to epicsThreadCreate(const char*, unsigned, unsigned, extern "C" void(*)(void*), void*) is being passed void(*)(void*).
"../epicsAtomicTest.cpp", line 240: Where: While instantiating "testIncrDecr<unsigned>()".
"../epicsAtomicTest.cpp", line 240: Where: Instantiated from non-template code.
"../epicsAtomicTest.cpp", line 173: Warning (Anachronism): Formal argument funptr of type extern "C" void(*)(void*) in call to epicsThreadCreate(const char*, unsigned, unsigned, extern "C" void(*)(void*), void*) is being passed void(*)(void*).
"../epicsAtomicTest.cpp", line 241: Where: While instantiating "testAddSub<int>()".
"../epicsAtomicTest.cpp", line 241: Where: Instantiated from non-template code.
"../epicsAtomicTest.cpp", line 175: Warning (Anachronism): Formal argument funptr of type extern "C" void(*)(void*) in call to epicsThreadCreate(const char*, unsigned, unsigned, extern "C" void(*)(void*), void*) is being passed void(*)(void*).
"../epicsAtomicTest.cpp", line 242: Where: While instantiating "testAddSub<unsigned>()".
"../epicsAtomicTest.cpp", line 242: Where: Instantiated from non-template code.
"../epicsAtomicTest.cpp", line 208: Warning (Anachronism): Formal argument funptr of type extern "C" void(*)(void*) in call to epicsThreadCreate(const char*, unsigned, unsigned, extern "C" void(*)(void*), void*) is being passed void(*)(void*).
"../epicsAtomicTest.cpp", line 243: Where: While instantiating "testCAS<int>()".
"../epicsAtomicTest.cpp", line 243: Where: Instantiated from non-template code.
"../epicsAtomicTest.cpp", line 244: Where: While instantiating "testCAS<unsigned>()".
"../epicsAtomicTest.cpp", line 244: Where: Instantiated from non-template code.
"../epicsAtomicTest.cpp", line 245: Where: While instantiating "testCAS<void*>()".
"../epicsAtomicTest.cpp", line 245: Where: Instantiated from non-template code.
"../epicsAtomicTest.cpp", line 51: Warning: Could not find source for TestDataAddSub<int>::delta.
"../epicsAtomicTest.cpp", line 51: Warning: Could not find source for TestDataAddSub<unsigned>::delta.
13 Warning(s) detected.
/opt/SUNWspro/bin/CC -o epicsAtomicTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -mt -z ignore -z combreloc -z lazyload epicsAtomicTest.o -lCom
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../macDefExpandTest.c
/opt/SUNWspro/bin/CC -o macDefExpandTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -mt -z ignore -z combreloc -z lazyload macDefExpandTest.o -lCom
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../macLibTest.c
/opt/SUNWspro/bin/CC -o macLibTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -mt -z ignore -z combreloc -z lazyload macLibTest.o -lCom
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../taskwdTest.c
/opt/SUNWspro/bin/CC -o taskwdTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -mt -z ignore -z combreloc -z lazyload taskwdTest.o -lCom
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../blockingSockTest.cpp
/opt/SUNWspro/bin/CC -o blockingSockTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -mt -z ignore -z combreloc -z lazyload blockingSockTest.o -lCom -lsocket
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../epicsMessageQueueTest.cpp
/opt/SUNWspro/bin/CC -o epicsMessageQueueTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -mt -z ignore -z combreloc -z lazyload epicsMessageQueueTest.o -lCom
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../epicsStackTraceTest.c
/opt/SUNWspro/bin/CC -o epicsStackTraceTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -mt -z ignore -z combreloc -z lazyload epicsStackTraceTest.o -lCom
/opt/SUNWspro/bin/CC -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -O +w -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../ipAddrToAsciiTest.cpp
/opt/SUNWspro/bin/CC -o ipAddrToAsciiTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -mt -z ignore -z combreloc -z lazyload ipAddrToAsciiTest.o -lCom
/opt/SUNWspro/bin/cc -DUNIX -DSOLARIS=10 -mt -D__EXTENSIONS__ -xc99 -D_POSIX_C_SOURCE=200112L -xO4 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include -c ../osiSockTest.c
/opt/SUNWspro/bin/CC -o osiSockTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -mt -z ignore -z combreloc -z lazyload osiSockTest.o -lCom
Undefined first referenced
symbol in file
__xnet_getsockopt osiSockTest.o (symbol belongs to implicit dependency /lib/libsocket.so.1)
setsockopt osiSockTest.o (symbol belongs to implicit dependency /lib/libsocket.so.1)
ld: fatal: symbol referencing errors. No output written to osiSockTest
../../../../configure/RULES_BUILD:201: recipe for target 'osiSockTest' failed
make[3]: *** [osiSockTest] Error 1
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/src/libCom/test/O.solaris-sparc'>
../../../configure/RULES_ARCHS:58: recipe for target 'install.solaris-sparc' failed
make[2]: *** [install.solaris-sparc] Error 2
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/src/libCom/test'>
../configure/RULES_DIRS:84: recipe for target 'libCom/test.install.solaris-sparc' failed
make[1]: *** [libCom/test.install.solaris-sparc] Error 2
make[1]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/src'>
configure/RULES_DIRS:84: recipe for target 'src.install.solaris-sparc' failed
make: *** [src.install.solaris-sparc] Error 2
Build step 'Execute shell' marked build as failure
[WARNINGS] Skipping publisher since build result is FAILURE
- Jenkins build is back to normal : epics-base-3.15-sol #106 APS Jenkins
Re: pva2pva build on APS Jenkins Michael Davidsaver
Jenkins build is back to normal : epics-base-3.15-test #33 APS Jenkins
<2017>
2025
<2017>
2025
