2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: moving initHooks into libCom
To: Mark Rivers <[email protected]>, 'Michael Davidsaver' <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 8 Dec 2017 14:51:14 -0600
On 12/08/2017 02:48 PM, Mark Rivers wrote:
> I have tested that fix on VS2015 and VS2017.  It fixes the problem.
> I am now building all of R7.0.1-rc1 with that patch on 2010, 2015,
> and 2017.
Great!
Michael, please push that commit to the master branch on github.
- Andrew
>> -----Original Message-----
>> From: [email protected] [mailto:[email protected]] On Behalf
>> Of Michael Davidsaver
>> Sent: Friday, December 08, 2017 2:32 PM
>> To: Andrew Johnson; [email protected]
>> On 12/08/2017 03:29 PM, Andrew Johnson wrote:
>>> Michael,
>>> In case your Inbox filters out Jenkins emails the epics-master-windows
>>> APS job is now demonstrating the pva2pva build failure.
>> I noticed.  If this is the only failure, then I might have it sorted out quickly.
>> https://github.com/mdavidsaver/pva2pva/commit/049ed8cead5e59dea7f6631698c45ea63db
>> 78d66
>>> Thanks,
>>> - Andrew
>>> On 12/08/2017 02:09 PM, Andrew Johnson wrote:
>>>> On 12/08/2017 01:57 PM, Mark Rivers wrote:
>>>>> I forget exactly what CALL does, but I don't think it's necessary.  It's
>>>>> worth trying I guess.
>>>> Yes, that fixed it. Jenkins runs build commands inside its own .BAT
>>>> file, and apparently executing one .BAT file inside another stops the
>>>> parent script. It's currently compiling using
>>>>> Microsoft (R) C/C++ Optimizing Compiler Version 19.00.24215.1 for x64
>>>> as against
>>>>> Microsoft (R) C/C++ Optimizing Compiler Version 16.00.40219.01 for x64
>>>>> Can you try the command interactively on that machine?
>>>> I can't open a command window with the Jenkins build environment, the
>>>> Jenkins agent sets up the shell environment by itself, and it's
>>>> complicated by the fact that it's all running inside a JVM too.
>>>> - Andrew
Re: moving initHooks into libCom Michael Davidsaver
RE: moving initHooks into libCom Mark Rivers
Re: moving initHooks into libCom Andrew Johnson
Prev: RE: moving initHooks into libCom Mark Rivers
Next: Re: moving initHooks into libCom Michael Davidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
