2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: moving initHooks into libCom
To: Andrew Johnson <[email protected]>, Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 8 Dec 2017 15:55:42 -0500
On 12/08/2017 03:51 PM, Andrew Johnson wrote:
> On 12/08/2017 02:48 PM, Mark Rivers wrote:
>> I have tested that fix on VS2015 and VS2017.  It fixes the problem.
>> I am now building all of R7.0.1-rc1 with that patch on 2010, 2015,
>> and 2017.
> Great!
> Michael, please push that commit to the master branch on github.
I just did.  As a matter of course I wait for a successful travis-ci build from
a branch in my personal repo before pushing to the main repo.
> - Andrew
>>> -----Original Message-----
>>> From: [email protected] [mailto:[email protected]] On Behalf
>>> Of Michael Davidsaver
>>> Sent: Friday, December 08, 2017 2:32 PM
>>> To: Andrew Johnson; [email protected]
>>> On 12/08/2017 03:29 PM, Andrew Johnson wrote:
>>>> Michael,
>>>> In case your Inbox filters out Jenkins emails the epics-master-windows
>>>> APS job is now demonstrating the pva2pva build failure.
>>> I noticed.  If this is the only failure, then I might have it sorted out quickly.
>>> https://github.com/mdavidsaver/pva2pva/commit/049ed8cead5e59dea7f6631698c45ea63db
>>> 78d66
>>>> Thanks,
>>>> - Andrew
>>>> On 12/08/2017 02:09 PM, Andrew Johnson wrote:
>>>>> On 12/08/2017 01:57 PM, Mark Rivers wrote:
>>>>>> I forget exactly what CALL does, but I don't think it's necessary.  It's
>>>>>> worth trying I guess.
>>>>> Yes, that fixed it. Jenkins runs build commands inside its own .BAT
>>>>> file, and apparently executing one .BAT file inside another stops the
>>>>> parent script. It's currently compiling using
>>>>>> Microsoft (R) C/C++ Optimizing Compiler Version 19.00.24215.1 for x64
>>>>> as against
>>>>>> Microsoft (R) C/C++ Optimizing Compiler Version 16.00.40219.01 for x64
>>>>>> Can you try the command interactively on that machine?
>>>>> I can't open a command window with the Jenkins build environment, the
>>>>> Jenkins agent sets up the shell environment by itself, and it's
>>>>> complicated by the fact that it's all running inside a JVM too.
>>>>> - Andrew
Re: moving initHooks into libCom Andrew Johnson
moving initHooks into libCom Michael Davidsaver
Re: moving initHooks into libCom Michael Davidsaver
RE: moving initHooks into libCom Mark Rivers
Prev: Re: moving initHooks into libCom Andrew Johnson
Next: RE: moving initHooks into libCom Mark Rivers
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: moving initHooks into libCom Andrew Johnson
