2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~epics-core/epics-base/+git/Com:iocsherr into epics-base:7.0
From: Keenan Lang via Core-talk <[email protected]>
To: mdavidsaver <[email protected]>
Date: Fri, 03 May 2019 18:42:32 -0000
>Is it possible for Keenan to hook into this mechanism from the synApps lua shell?
It gets registered into the IOC function registrar, so I have access to be able to use it in the same way as a startup script does by calling iocsh.on("error", "halt"). Were you imagining anything more than that?
https://code.launchpad.net/~epics-core/epics-base/+git/Com/+merge/366876
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
[Merge] ~epics-core/epics-base/+git/Com:iocsherr into epics-base:7.0 mdavidsaver via Core-talk
Prev: Re: [Merge] ~epics-core/epics-base/+git/Com:iocsherr into epics-base:7.0 Andrew Johnson via Core-talk
Next: Re: [Merge] ~epics-core/epics-base/+git/Com:iocsherr into epics-base:7.0 Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 03 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
