2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~epics-core/epics-base/+git/Com:iocsherr into epics-base:7.0
From: Andrew Johnson via Core-talk <[email protected]>
To: mdavidsaver <[email protected]>
Date: Fri, 03 May 2019 19:21:23 -0000
@Keenan: It isn't the "on" command itself I was thinking about so much as the effect that it has, which is to save the "what to do if there's an error" instruction from it and then later do that thing if a command returns an error status. Since a lua "iocsh.cmd(args)" statement ends up calling the same cmd_callFunc() that iocsh does (which returns void), lua doesn't see any error status either, so the only way to know whether the command flagged an error or not would be to ask iocsh if iocshSetError() was called, hence your need for an iocshGetError() routine.
https://code.launchpad.net/~epics-core/epics-base/+git/Com/+merge/366876
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
[Merge] ~epics-core/epics-base/+git/Com:iocsherr into epics-base:7.0 mdavidsaver via Core-talk
Prev: Re: [Merge] ~epics-core/epics-base/+git/Com:iocsherr into epics-base:7.0 Keenan Lang via Core-talk
Next: Build failed: EPICS Base base-3.15-392 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: Re: [Merge] ~epics-core/epics-base/+git/Com:iocsherr into epics-base:7.0 Keenan Lang via Core-talk
ANJ, 03 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
