2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0
From: Dirk Zimoch via Core-talk <[email protected]>
To: mdavidsaver <[email protected]>
Date: Fri, 10 May 2019 14:59:52 -0000
> I hadn't come across https://github.com/raspberrypi/tools previously.  Having
> seen it, I don't think I would ever use it!
> Judging by the (3 year old) commit message, these binaries are from a
> crosstool-ng built, not the native raspbian.  ABI mis-matches with the raspian
> toolchain are to be expected.
There is a comment about readline in the file.
> fyi. seeing linking issues involving libtinfo.so is a sign of mixing debian
> and non-debian builds of readline.
> If you use this toolchain then imo. full static linking (including libc) is a
> must!
> If interop with raspbian libs is desirable, then I'd suggest looking at QEMU
> user mode emulation to run the hosted toolchain.
> https://wiki.debian.org/RaspberryPi/qemu-user-static
This was the "official" cross tool chain, AFAIK.
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/367256
Your team EPICS Core Developers is requested to review the proposed merge of ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0.
Re: [Merge] ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0 mdavidsaver via Core-talk
Prev: Re: [Merge] ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0 Dirk Zimoch via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0 Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0 mdavidsaver via Core-talk
ANJ, 10 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
