2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0
From: Andrew Johnson via Core-talk <[email protected]>
To: [email protected]
Date: Fri, 10 May 2019 16:02:26 -0000
Is this configuration intended for cross-building? Have you used it for building native as well?
The EPICS build system was designed so that end-users should never have to modify any CONFIG.* files to build Base, they should only edit CONFIG_SITE.* files, so your SDK_TARGET value should get in a CONFIG_SITE.* file. If this configuration is used for cross-building only then it really belongs in a CONFIG_SITE.<host-arch>.raspbian-arm file, the CONFIG.Common.<target-arch> files are for things that really are specific to the target irrespective of where the code is being compiled.
I have asked Pete Jemian who has lots of experience with running EPICS on the Pi for his comments too.
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/367256
Your team EPICS Core Developers is requested to review the proposed merge of ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0.
Re: [Merge] ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: Re: [Merge] ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0 Dirk Zimoch via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0 Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: Re: [Merge] ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0 Dirk Zimoch via Core-talk
ANJ, 10 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
