2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0
From: Andrew Johnson via Core-talk <[email protected]>
To: [email protected]
Date: Fri, 10 May 2019 16:27:38 -0000
There seem to be a number of possibilities for Raspbian cross-building, the various answers to the stack-overflow question at https://stackoverflow.com/questions/19162072/how-to-install-the-raspberry-pi-cross-compiler-on-my-linux-host-machine show several options. The Github tool-chain that Dirk is using does seem to be the "official" one. A fairly comprehensive alternative set with more recent versions is available at https://github.com/abhiTronix/raspberry-pi-cross-compilers
There is also a post on Medium at https://medium.com/@au42/the-useful-raspberrypi-cross-compile-guide-ea56054de187 that covers resolving library issues using the official tool-chain, but it's configuring application builds using CMAKE and I haven't looked at it in detail.
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/367256
Your team EPICS Core Developers is requested to review the proposed merge of ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0.
Re: [Merge] ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: Re: [Merge] ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0 Andrew Johnson via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:dynamicVxWorksVmeFunctionBinding into epics-base:7.0 Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0 Dirk Zimoch via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0 Dirk Zimoch via Core-talk
ANJ, 10 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
