2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:dynamicVxWorksVmeFunctionBinding into epics-base:7.0
From: Andrew Johnson via Core-talk <[email protected]>
To: [email protected]
Date: Fri, 10 May 2019 17:19:45 -0000
Why not just replace the  #if  lines with  if (...) {  and leave the bodies of the functions untouched? That would make it easier for reviewers to confirm that you aren't changing the logic at all. As it is we have to understand both the original logic and what you've replaced it with and convince ourselves that their behavior will be the same, but using run-time detection instead of compile-time. Modern compilers should generate the same code for both versions so human readability is more important than conciseness.
I know that some people don't like having multiple return statements in a function; personally I disagree with that position, especially in simple cases like these where there are no resources that need releasing.
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/367253
Your team EPICS Core Developers is requested to review the proposed merge of ~dirk.zimoch/epics-base:dynamicVxWorksVmeFunctionBinding into epics-base:7.0.
[Merge] ~dirk.zimoch/epics-base:dynamicVxWorksVmeFunctionBinding into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: Re: [Merge] ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0 Andrew Johnson via Core-talk
Next: Jenkins build is unstable: epics-7.0 » linux64 #127 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: [Merge] ~dirk.zimoch/epics-base:dynamicVxWorksVmeFunctionBinding into epics-base:7.0 Dirk Zimoch via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:dynamicVxWorksVmeFunctionBinding into epics-base:7.0 Dirk Zimoch via Core-talk
ANJ, 14 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
