2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:dynamicVxWorksVmeFunctionBinding into epics-base:7.0
From: Dirk Zimoch via Core-talk <[email protected]>
To: [email protected]
Date: Wed, 15 May 2019 07:26:58 -0000
The problem here was that not every vxWorks system has a VME bus and thus loading EPICS base failed with unresolved symbols. This applies to each library/module that has vxWorks support for VME mixed with code for other useful stuff. At the moment if you want the other stuff you must have VME. So yes, that may apply to devLib2 as well.
However so far I only had one such system, that is an old CompactRIO fom NI. And on that system I do not use devLib2. So I have not noticed a problem.
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/367253
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
[Merge] ~dirk.zimoch/epics-base:dynamicVxWorksVmeFunctionBinding into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: Re: [Merge] ~dirk.zimoch/epics-base:dynamicVxWorksVmeFunctionBinding into epics-base:7.0 mdavidsaver via Core-talk
Next: _WIN32_WINNT defines in EPICS base Freddie Akeroyd - UKRI STFC via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: [Merge] ~dirk.zimoch/epics-base:dynamicVxWorksVmeFunctionBinding into epics-base:7.0 noreply--- via Core-talk
ANJ, 28 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
