2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: _WIN32_WINNT defines in EPICS base
From: Freddie Akeroyd - UKRI STFC via Core-talk <[email protected]>
To: "EPICS core-talk ([email protected])" <[email protected]>
Date: Wed, 15 May 2019 10:28:52 +0000
I was recently compiling EPICS base 3.15 for an earlier windows version from Windows 10 and had a compile error with the WIN32 base implementation of  SetThreadName.cpp. The file always sets _WIN32_WINNT to 0x400 (Specifying Windows NT 4.0, the comment says it is dropping support for W95!) which then conflicted with my setting of NTDDI_VERSION. The  _WIN32_WINNT macro is also set to 0x400 in osdMutex.c and osdThread.c but in these files it is only set if not otherwise defined externally. A similar check for an existing definition in SetThreadName.cpp would avoid my compile issue, but as Windows 95 and NT 4.0 are long in the past I wonder if removing these redefinitions of _WIN32_WINNT from base would now be appropriate
Freddie
Re: _WIN32_WINNT defines in EPICS base Johnson, Andrew N. via Core-talk
Prev: Re: [Merge] ~dirk.zimoch/epics-base:dynamicVxWorksVmeFunctionBinding into epics-base:7.0 Dirk Zimoch via Core-talk
Next: Re: Excessive scan times for periodic scans Konrad, Martin via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: [Bug 1828900] [NEW] dbUnitTest::testdbRecordPtr() is easy to mis-use Andrew Johnson via Core-talk
Next: Re: _WIN32_WINNT defines in EPICS base Johnson, Andrew N. via Core-talk
ANJ, 15 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
