2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: _WIN32_WINNT defines in EPICS base
From: "Johnson, Andrew N. via Core-talk" <[email protected]>
Date: Wed, 15 May 2019 18:15:59 +0000
Hi Freddie,
On 5/15/19 5:28 AM, Freddie Akeroyd - UKRI STFC via Core-talk wrote:
I was recently compiling EPICS base 3.15 for an earlier windows version from Windows 10 and had a compile error with the WIN32 base implementation of  SetThreadName.cpp. The file always sets _WIN32_WINNT to 0x400 (Specifying Windows NT 4.0, the comment says it is dropping support for W95!) which then conflicted with my setting of NTDDI_VERSION. The  _WIN32_WINNT macro is also set to 0x400 in osdMutex.c and osdThread.c but in these files it is only set if not otherwise defined externally. A similar check for an existing definition in SetThreadName.cpp would avoid my compile issue, but as Windows 95 and NT 4.0 are long in the past I wonder if removing these redefinitions of _WIN32_WINNT from base would now be appropriate
If you think we can safely remove all those tests and definitions from libCom/osi/os/WIN32 for the "recent-enough" versions of Windows we should support I'd be fine with doing that.
I just tried it on windows-x64 and windows-x64-mingw builds and MSVC gave me a deprecation warning for the GetVersionEx() call in epicsMutexOsdCreate() — could we remove the thisIsNT variable and CreateMutex() stuff from osdMutex.c as well while we're cleaning this up? It looks like the required CRITICAL_SECTION support is present back as far as Windows XP and Windows Server 2003, which is fine as far as I'm concerned.
- Andrew
Complexity comes for free, Simplicity you have to work for.
RE: _WIN32_WINNT defines in EPICS base Freddie Akeroyd - UKRI STFC via Core-talk
Prev: Re: Excessive scan times for periodic scans Konrad, Martin via Core-talk
Next: Build failed in Jenkins: 3.15-pva2pva-win64s #205 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: _WIN32_WINNT defines in EPICS base Freddie Akeroyd - UKRI STFC via Core-talk
Next: RE: _WIN32_WINNT defines in EPICS base Freddie Akeroyd - UKRI STFC via Core-talk
ANJ, 17 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
