2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~anj/epics-base/+git/base-3.15:decimate-filter into epics-base:3.15
From: Andrew Johnson via Core-talk <[email protected]>
Date: Mon, 08 Jul 2019 17:57:03 -0000
I tried adding code to set the pfl->field_size member in fl_setup(), but that wasn't enough to fix the valgrind reports and was also missing from the syncTest.c and dbndTest.c programs. I therefor added an initial memset(), which did fix them.
Last night I also committed some additional tests to those 3 programs which check for the expected number of items on the freelist, and I also fixed some leaks in the sync filter.
https://code.launchpad.net/~anj/epics-base/+git/base-3.15/+merge/368347
Your team EPICS Core Developers is subscribed to branch epics-base:3.15.
[Merge] ~anj/epics-base/+git/base-3.15:decimate-filter into epics-base:3.15 Andrew Johnson via Core-talk
Prev: Re: [Merge] ~freddie-akeroyd/epics-base:msi_close_file into epics-base:3.15 mdavidsaver via Core-talk
Next: Re: [Merge] ~freddie-akeroyd/epics-base:msi_close_file into epics-base:3.15 Freddie Akeroyd via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~anj/epics-base/+git/base-3.15:decimate-filter into epics-base:3.15 mdavidsaver via Core-talk
Next: Re: [Merge] ~anj/epics-base/+git/base-3.15:decimate-filter into epics-base:3.15 Andrew Johnson via Core-talk
ANJ, 09 Jul 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
