2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~freddie-akeroyd/epics-base:msi_close_file into epics-base:3.15
From: Freddie Akeroyd via Core-talk <[email protected]>
To: [email protected]
Date: Mon, 08 Jul 2019 22:41:01 -0000
I think a final fflush could work too, i can check that if it would be preferred over closing stdout. All the freopen() examples seemed to use fclose(), but the internet is a bit divided over whether you should always fclose(stdout) at end of main as there could be an atexit() handler that wrote to stdout for example. I suppose fclose(stdout) could be registered via atexit as the last exit handler, but that may be overkill for the msi program
https://code.launchpad.net/~freddie-akeroyd/epics-base/+git/epics-base/+merge/369763
Your team EPICS Core Developers is requested to review the proposed merge of ~freddie-akeroyd/epics-base:msi_close_file into epics-base:3.15.
[Merge] ~freddie-akeroyd/epics-base:msi_close_file into epics-base:3.15 Freddie Akeroyd via Core-talk
Prev: Re: [Merge] ~anj/epics-base/+git/base-3.15:decimate-filter into epics-base:3.15 Andrew Johnson via Core-talk
Next: Re: [Merge] ~freddie-akeroyd/epics-base:msi_close_file into epics-base:3.15 Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~freddie-akeroyd/epics-base:msi_close_file into epics-base:3.15 mdavidsaver via Core-talk
ANJ, 08 Jul 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
