2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~epics-core/epics-base/+git/asLib:as-hostname into epics-base:7.0
From: mdavidsaver via Core-talk <[email protected]>
To: mdavidsaver <[email protected]>
Date: Mon, 26 Aug 2019 20:52:00 -0000
I'm planning to go ahead and merge with a default of asCheckClientIP=0.  Changing this can be a separate discussion.
> Why are you (consistently) allocating 24?
Force of habit?  I can't recall.
> default value of asCheckClientIP
Can we agree that the desired final solution is defaulting to asCheckClientIP=1 ?
> Admittedly this is an unusual situation
Yup, given the number of sites not using ACF at all.
Is it worth my arguing that any site bothering with access control
would likely welcome stronger authentication?
> canonical hostname ... a secondary network interface with a different DNS name
> ... it could ...
How could this be done?  I can't think of a way.
> has better things to do
Granted.  It would still be nice to document a possible course of action in case someone is motivated.
https://code.launchpad.net/~epics-core/epics-base/+git/asLib/+merge/358822
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
Prev: Re: Strange behavior of async calcout with CPP input link Michael Davidsaver via Core-talk
Next: Re: Strange behavior of async calcout with CPP input link Johnson, Andrew N. via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: [Merge] ~epics-core/epics-base/+git/asLib:as-hostname into epics-base:7.0 Andrew Johnson via Core-talk
Next: Re: [Merge] ~epics-core/epics-base/+git/asLib:as-hostname into epics-base:7.0 Andrew Johnson via Core-talk
ANJ, 26 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
