2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~epics-core/epics-base/+git/asLib:as-hostname into epics-base:7.0
From: Andrew Johnson via Core-talk <[email protected]>
To: mdavidsaver <[email protected]>
Date: Mon, 26 Aug 2019 22:23:10 -0000
> Can we agree that the desired final solution is defaulting to asCheckClientIP=1 ?
Yes, I'd just like there to be something like a couple of releases where people can try it out before we flip the default.
> Is it worth my arguing that any site bothering with access control would likely welcome stronger authentication?
We use AS here to prevent people from fiddling with PVs that only the experts should be modifying, such as some of our RF system IOCs where a mis-placed put might be able to destroy one of our dwindling supply of RF cavities. I'm totally guessing whether that might be possible, but I do know that our RF IOCs do use it quite extensively, as do our beamline gateways. I agree that stronger authentication is better, and that this will give us stronger authentication.
> How could this be done?
Instead of making this a binary switch, store both the HAG name and the DNS result. Implement the host comparisons using both methods simultaneously and cross-check the results. When the by-name comparison says Match but the by-DNS says No there's either someone trying to impersonate a different client machine or this could be a multiple-interface name issue. You aren't modifying the actual host comparison code at all here though, so doing this would need more extensive changes to asLib.
Similarly larger changes would be needed to allow the use of IP address ranges in the ASCF (e.g. 192.168.12.16/28 say) which I could see as being useful to some (and would need more than 16 chars to store).
https://code.launchpad.net/~epics-core/epics-base/+git/asLib/+merge/358822
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
Prev: Re: Strange behavior of async calcout with CPP input link Johnson, Andrew N. via Core-talk
Next: Build failed: epics-base base-iocsherr-284 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~epics-core/epics-base/+git/asLib:as-hostname into epics-base:7.0 mdavidsaver via Core-talk
Next: [Merge] ~epics-core/epics-base/+git/asLib:as-hostname into epics-base:7.0 noreply--- via Core-talk
ANJ, 31 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
