2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: [Bug 1810949] Re: Memory leak in MSI
From: Andrew Johnson via Core-talk <[email protected]>
To: [email protected]
Date: Thu, 31 Oct 2019 19:50:03 -0000
** Changed in: epics-base/3.15
       Status: Fix Committed => Fix Released
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1810949
Title:
  Memory leak in MSI
Status in EPICS Base:
  Fix Released
Status in EPICS Base 3.15 series:
  Fix Released
Status in EPICS Base 7.0 series:
  Fix Released
Bug description:
  MSI in Base 3.15 has a memory leak:
  $ cd src/ioc/dbtemplate/test/O.linux-x86_64-debug
  $ valgrind --leak-check=full --track-origins=yes ./msi-copy -I. -I.. -S ../t2-substitution.txt
  ==3718== 4,096 bytes in 1 blocks are definitely lost in loss record 67 of 69
  ==3718==    at 0x4839775: calloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
  ==3718==    by 0x10C682: catMacroReplacements (msi.c:1120)
  ==3718==    by 0x10C11C: substituteGetReplacements (msi.c:984)
  ==3718==    by 0x10A92E: main (msi.c:196)
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1810949/+subscriptions
Prev: [Bug 1835525] Re: Output truncated with MSI on WIN32 Andrew Johnson via Core-talk
Next: [Bug 1810946] Re: MSI doesn't handle empty substitution patterns correctly Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to stable : epics-pvAccess-linux32 #403 APS Jenkins via Core-talk
ANJ, 31 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
