2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: [Bug 1810946] Re: MSI doesn't handle empty substitution patterns correctly
From: Andrew Johnson via Core-talk <[email protected]>
To: [email protected]
Date: Thu, 31 Oct 2019 19:50:11 -0000
** Changed in: epics-base/3.15
       Status: Fix Committed => Fix Released
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1810946
Title:
Status in EPICS Base:
  Fix Released
Status in EPICS Base 3.15 series:
  Fix Released
Status in EPICS Base 7.0 series:
  Fix Released
Bug description:
  EPICS 3.15.6 doesn't handle empty substitution patterns correctly
  anymore:
  file "a.db" {
  results in
  msi: Parse error, unexpected '}'
  No problems with older versions of Base. I'm able to work around the
  problem by using:
  file "a.db" {
    { DUMMY="" }
  This regression was introduced by the following commit:
  https://git.launchpad.net/epics-
  base/commit/?h=3.15&id=67e2b74758982fd46be5529e28fcb93fd7eb59ad
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1810946/+subscriptions
Prev: [Bug 1810949] Re: Memory leak in MSI Andrew Johnson via Core-talk
Next: [Bug 1797634] Re: Broken shebang line in tap-to-junit-xml.pl Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
