2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: double filters
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: Ben Franksen <benjamin.franksen at helmholtz-berlin.de>
Cc: "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>
Date: Sun, 29 Mar 2020 00:26:25 +0000
Allowing multiple filters to be used chained together is most definitely something we want to support, although in most cases they would probably be different filters, say array to extract one value followed by a deadband filter say, possibly with a time stamp filter as well. Repeating the same kind of filter seems less necessary, but given that we can support it at no cost I don’t see why we should try to prevent it.
I understand that some JSON parsers won’t handle duplicate keys, is that what concerns you?
- Andrew
Complicity is easy, Simplexity takes real work
> On Mar 28, 2020, at 2:45 PM, Ben Franksen via Core-talk <core-talk at aps.anl.gov> wrote:
> The array filter test (modules/database/test/std/filters/arrTest.cpp)
> creates "double" array filters that look like:
>  {"arr":{},"arr":{"s":x,"e":y,"i":z}}
> Apparently this is interpreted by EPICS base to mean two array filters
> in succesion, first the left, then the right.
> According to the JSON standard this is allowed. But is it a good idea?
> Are there practical use cases? (The test where I've seen this doesn't
> count IMO).
> Cheers
> Ben
> ________________________________
> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher Forschungszentren e.V.
> Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
> Geschäftsführung: Prof. Dr. Bernd Rech (Sprecher), Prof. Dr. Jan Lüning, Thomas Frederking
> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
> Postadresse:
> Hahn-Meitner-Platz 1
> D-14109 Berlin
> <pEpkey.asc>
Re: double filters Ben Franksen via Core-talk
Re: double filters Ralph Lange via Core-talk
Prev: Re: [Merge] ~bfrk/epics-base:zero-size-array-request into epics-base:7.0 Ben Franksen via Core-talk
Next: Re: [Merge] ~anj/epics-base/+git/base-7.0:typed-dsets into epics-base:7.0 mdavidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: double filters Ben Franksen via Core-talk
Next: Re: double filters Ben Franksen via Core-talk
ANJ, 30 Mar 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
