2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: double filters
From: Ralph Lange via Core-talk <core-talk at aps.anl.gov>
To: EPICS Core Talk <core-talk at aps.anl.gov>
Date: Mon, 30 Mar 2020 09:31:31 +0200
On Sun, 29 Mar 2020 at 01:26, Johnson, Andrew N. via Core-talk <core-talk at aps.anl.gov> wrote:
Allowing multiple filters to be used chained together is most definitely something we want to support, although in most cases they would probably be different filters, say array to extract one value followed by a deadband filter say, possibly with a time stamp filter as well. Repeating the same kind of filter seems less necessary, but given that we can support it at no cost I don’t see why we should try to prevent it.
For the array filter, I would say that having two in a filter chain is not redundant if there is a filter in between the two that changes the meaning of data, i.e., an array-to-array function like FFT. Looking at a region of interest, Fourier-transform, then look at a specific part of the spectrum. Don't know if that is a valid use case, though, and there is no FFT filter.
Two array filters in a row seem redundant.
Cheers,
~Ralph
double filters Ben Franksen via Core-talk
Re: double filters Johnson, Andrew N. via Core-talk
Prev: Re: double filters Ralph Lange via Core-talk
Next: Re: double filters Ralph Lange via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Re: double filters Ben Franksen via Core-talk
ANJ, 03 Apr 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
