2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: double filters
From: Ralph Lange via Core-talk <core-talk at aps.anl.gov>
To: EPICS Core Talk <core-talk at aps.anl.gov>
Date: Mon, 30 Mar 2020 09:09:55 +0200
To answer the original question:
On Sat, 28 Mar 2020 at 20:45, Ben Franksen via Core-talk <core-talk at aps.anl.gov> wrote:
The array filter test (modules/database/test/std/filters/arrTest.cpp)
creates "double" array filters that look like:
  {"arr":{},"arr":{"s":x,"e":y,"i":z}}
Apparently this is interpreted by EPICS base to mean two array filters
in succession, first the left, then the right.
According to the JSON standard this is allowed. But is it a good idea?
Are there practical use cases? (The test where I've seen this doesn't
count IMO).
As far as I recall (that was 8 years ago, and Michael wrote the tests), that test verifies that the array filter functionality works inside a filter chain, i.e., with with another filter providing the input data, not a record.
The easiest way to achieve that without adding another dependency is to use two array filters in a chain. I don't think this test was driven by a specific use case.
Cheers,
~Ralph
double filters Ben Franksen via Core-talk
Prev: Re: [Merge] ~bfrk/epics-base:zero-size-array-request into epics-base:7.0 mdavidsaver via Core-talk
Next: Re: double filters Ralph Lange via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Re: double filters Ralph Lange via Core-talk
Next: debugger w/ reverse execution Michael Davidsaver via Core-talk
ANJ, 30 Mar 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
